Easy Drummer crashing 10.3.1
Easy Drummer, version 1.3.1 is crashing Pro Tools 10.3.1 on my system.
It worked fine in 10.2. I installed 10.3.1 as a clean install, after uninstalling 10.2 first. If open a session file that has an Easy Drummer instance, or if I try to import session data (importing a track that has Easy Drummer on the track), the result is a Pro Tools shut down. Anyone having this issue? I trashed prefs and repaired permissions with no change. Below is part of the Error report from OSX: Process: Pro Tools [255] Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.3.1.36 (10.3.1f36) Build Info: Unknown-1031036~36 Code Type: X86 (Native) Parent Process: launchd [121] Date/Time: 2012-10-13 00:31:59.455 -0500 OS Version: Mac OS X 10.7.4 (11E53) Report Version: 9 Interval Since Last Report: 817116 sec Crashes Since Last Report: 5 Per-App Interval Since Last Report: 318624 sec Per-App Crashes Since Last Report: 4 Anonymous UUID: 0641DE8A-B120-437B-B1BC-5E93EA358E4B Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x00000000e2cd16cd VM Regions Near 0xe2cd16cd: CG backing stores 00000000c5582000-00000000c61a4000 [ 12.1M] rw-/rw- SM=SHM --> Submap 00000000ffff0000-00000000ffff2000 r-x/r-x process-only submap Application Specific Information: objc[255]: garbage collection is OFF Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.toontrack.superior.auezdrummer 0x2625cb95 NewMachOPlugIn + 338373 1 com.toontrack.superior.auezdrummer 0x262b7254 NewMachOPlugIn + 708740 2 com.toontrack.superior.auezdrummer 0x262c8990 NewMachOPlugIn + 780224 3 com.toontrack.superior.auezdrummer 0x262c8bdc NewMachOPlugIn + 780812 4 com.toontrack.superior.auezdrummer 0x2627dfd2 NewMachOPlugIn + 474626 5 com.toontrack.superior.auezdrummer 0x2627d0dd NewMachOPlugIn + 470797 6 com.toontrack.superior.auezdrummer 0x262c70e6 NewMachOPlugIn + 773910 7 com.toontrack.superior.auezdrummer 0x262dbc7d NewMachOPlugIn + 858797 8 com.toontrack.superior.auezdrummer 0x2629ac10 NewMachOPlugIn + 592448 9 com.toontrack.superior.auezdrummer 0x262b5d97 NewMachOPlugIn + 703431 10 com.toontrack.superior.auezdrummer 0x2621637f NewMachOPlugIn + 49583 11 com.toontrack.superior.auezdrummer 0x26208b48 0x26200000 + 35656 12 com.toontrack.superior.auezdrummer 0x262f2f01 NewMachOPlugIn + 953649 13 com.toontrack.superior.auezdrummer 0x262047bb 0x26200000 + 18363 14 com.toontrack.superior.auezdrummer 0x2620663e 0x26200000 + 26174 15 com.digidesign.framework.DAE 0x0c62da34 FicGetApplicationInterface + 43332 16 com.digidesign.framework.DAE 0x0c73e433 FicSetPlugInChunk + 51 17 com.digidesign.framework.ProTools 0x0a238170 MFortressHWBPEntryPoint_exit_mfort6317_ + 8282982 18 com.digidesign.framework.ProTools 0x0a012cac MFortressHWBPEntryPoint_exit_mfort6317_ + 6033058 19 com.digidesign.framework.ProTools 0x0a06598b MFortressHWBPEntryPoint_exit_mfort6317_ + 6372225 20 com.digidesign.framework.ProTools 0x09fed66b MFortressHWBPEntryPoint_exit_mfort6317_ + 5879905 21 com.digidesign.framework.ProTools 0x0a0f5d4b MFortressHWBPEntryPoint_exit_mfort6317_ + 6963009 22 com.digidesign.framework.ProTools 0x0a060ea8 MFortressHWBPEntryPoint_exit_mfort6317_ + 6353054 23 com.digidesign.framework.ProTools 0x0a15fd89 MFortressHWBPEntryPoint_exit_mfort6317_ + 7397247 24 com.digidesign.framework.ProTools 0x0a14556e MFortressHWBPEntryPoint_exit_mfort6317_ + 7288676 25 com.digidesign.framework.ProTools 0x0b243334 MFortressHWBPEntryPoint_exit_mfort6317_ + 25105706 26 com.digidesign.framework.ProTools 0x0ae7dd41 MFortressHWBPEntryPoint_exit_mfort6317_ + 21151543 27 com.digidesign.framework.DFW 0x005955eb TCommandHandler::PerformCommand(TCommand*) + 187 28 com.digidesign.framework.DFW 0x00595f3f TCommand::Process() + 31 29 com.digidesign.framework.ProTools 0x0a8e7a58 MFortressHWBPEntryPoint_exit_mfort6317_ + 15293518 30 com.digidesign.framework.DFW 0x0058b9ea TApplication::ProcessEvent(TEvent*) + 26 31 com.digidesign.framework.DFW 0x0058c300 TApplication::WakeUp() + 64 32 com.digidesign.framework.DFW 0x006f192b TApplication::CreateNewOSApplication(void*, void*, void*) + 667 33 com.apple.HIToolbox 0x9b143dec _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 34 com.apple.HIToolbox 0x9afbf4f3 _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 1602 35 com.apple.HIToolbox 0x9afbe970 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 36 com.apple.HIToolbox 0x9afbe788 SendEventToEventTargetWithOptions + 75 37 com.apple.HIToolbox 0x9afd43aa _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHa ndlerCallRefP14OpaqueEventRefPv + 3152 38 com.apple.HIToolbox 0x9afbf9ae _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 2813 39 com.apple.HIToolbox 0x9afbe970 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482 40 com.apple.HIToolbox 0x9afd3755 SendEventToEventTarget + 76 41 com.apple.HIToolbox 0x9b143c38 ToolboxEventDispatcher + 82 42 com.apple.HIToolbox 0x9b143d67 RunApplicationEventLoop + 236 43 com.digidesign.framework.DFW 0x006fae6b DFW_EventLoop::RunApplicationEventLoop() + 11 44 com.digidesign.framework.DFW 0x0058babd TApplication::Run() + 45 45 com.digidesign.framework.ProTools 0x0b45f3d8 MFortressHWBPEntryPoint_exit_mfort6317_ + 27317710 46 com.digidesign.framework.ProTools 0x0b460b59 LaunchProTools + 1305 47 com.digidesign.ProTools 0x0000f317 0x1000 + 58135 48 com.digidesign.ProTools 0x0001041a 0x1000 + 62490 49 com.digidesign.ProTools 0x0000f09d 0x1000 + 57501 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x97ef490a kevent + 10 1 libdispatch.dylib 0x95c83e10 _dispatch_mgr_invoke + 969 2 libdispatch.dylib 0x95c8285f _dispatch_mgr_thread + 53 Thread 2: 0 libsystem_kernel.dylib 0x97ef1c5e semaphore_wait_trap + 10 1 com.digidesign.framework.digitrace 0x013ef98a digitrace_initialize + 10122 2 com.digidesign.framework.digitrace 0x013f40df DigiTraceIsActiveFunc + 1263 3 com.digidesign.framework.digitrace 0x013f4265 DigiTraceIsActiveFunc + 1653 4 com.digidesign.framework.digitrace 0x013f43c1 DigiTraceIsActiveFunc + 2001 5 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 6 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 3: 0 libsystem_kernel.dylib 0x97ef1c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x97ef11f6 mach_msg + 70 2 com.apple.CoreFoundation 0x9042a9da __CFRunLoopServiceMachPort + 170 3 com.apple.CoreFoundation 0x90433b04 __CFRunLoopRun + 1428 4 com.apple.CoreFoundation 0x904331dc CFRunLoopRunSpecific + 332 5 com.apple.CoreFoundation 0x90443f01 CFRunLoopRun + 129 6 com.digidesign.framework.ProTools 0x0b45cf17 MFortressHWBPEntryPoint_exit_mfort6317_ + 27308301 7 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 8 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 4: 0 libsystem_kernel.dylib 0x97ef1c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x97ef11f6 mach_msg + 70 2 com.digidesign.framework.CoreFoundation 0x002522e2 Sys_MachExceptionHandler::Init(bool, int) + 706 3 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 4 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 5: 0 libsystem_kernel.dylib 0x97ef1c22 mach_msg_trap + 10 1 libsystem_kernel.dylib 0x97ef11f6 mach_msg + 70 2 com.apple.CoreFoundation 0x9042a9da __CFRunLoopServiceMachPort + 170 3 com.apple.CoreFoundation 0x90433b04 __CFRunLoopRun + 1428 4 com.apple.CoreFoundation 0x904331dc CFRunLoopRunSpecific + 332 5 com.apple.CoreFoundation 0x90443f01 CFRunLoopRun + 129 6 com.digidesign.framework.DAE 0x0c60b737 FicIsAlive + 983 7 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 8 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 6: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cb52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x0024c7b6 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x002301f0 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 9 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 7: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cb52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x0024c7b6 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x002301f0 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 9 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 8: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cb52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.DAE 0x0c6784b0 FicGetContiguousMemRequirements + 148736 4 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 8 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 9: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cb52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x0024c7b6 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x002301f0 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 9 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 10: 0 com.digidesign.framework.DAE 0x0c6d7ffe FWMidiCallback + 316702 1 com.digidesign.framework.DAE 0x0c6d9935 FWMidiCallback + 323157 2 com.digidesign.framework.DAE 0x0c6d9b04 FWMidiCallback + 323620 3 com.digidesign.framework.DAE 0x0c6b433b FWMidiCallback + 170075 4 com.digidesign.framework.DAE 0x0c6b0fd4 FWMidiCallback + 156916 5 com.digidesign.framework.DAE 0x0c6b2576 FWMidiCallback + 162454 6 com.digidesign.framework.DAE 0x0c6b28bb FWMidiCallback + 163291 7 com.digidesign.framework.DAE 0x0c705f42 FWMidiCallback + 504930 8 com.digidesign.framework.PlatformSupport 0x008c12b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 9 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 10 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 11: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0c705fa5 FWMidiCallback + 505029 3 com.digidesign.framework.DAE 0x0c6b2693 FWMidiCallback + 162739 4 com.digidesign.framework.DAE 0x0c705f42 FWMidiCallback + 504930 5 com.digidesign.framework.PlatformSupport 0x008c12b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 12: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0d0f3e72 DSK_ParsedZone::Reset() + 22098 3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 13: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0d0f3e72 DSK_ParsedZone::Reset() + 22098 3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 14: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0d0f3e72 DSK_ParsedZone::Reset() + 22098 3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 15: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0d0f3e72 DSK_ParsedZone::Reset() + 22098 3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34 Thread 16: 0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0d0efd8c DSK_ParsedZone::Reset() + 5484 3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335 7 libsystem_c.dylib 0x995b46de thread_start + 34
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache |
Re: Easy Drummer crashing 10.3.1
I'm don't know about EZ Drummer version 1.3.1 with PT 10.3.1 as I have not updated to that version of Pro Tools to date.
I can say that I am having no problems with EZ Drummer 1.3.1 or Superior Drummer 2.3.0 with PT version 10.3.0. Then again, I'm on a Windows platform so I'm not sure this helps. Lou
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD Catalina 10.15.7 Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors. Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves. |
Many folks are having problems with 10.3.1 that they weren't having with 10.3.0. Don't forget that there is a sticky at the top of all of the Pro Tools 10 forum pages with an Avid alert about one of them. Until they fix a bunch of the issues going back to 10.3.0 is probably the best idea for now.
Thanks guys. The bummer is that 10.3.1 fixed the "white noise at the end of a region when recording" issue for me, but then created this new problem.
I skipped over 10.3.0, maybe I'll install and try that.
Superior Drummer 2.2.1 Crashing | davebmetal | RTAS & TDM Plug-ins | 4 | 05-06-2013 10:18 AM |
Superior Drummer crashing on multi out? | necjamc | Pro Tools M-Powered (Win) | 6 | 05-09-2010 01:35 AM |
EZ Drummer not so easy | Ode Man | Tips & Tricks | 3 | 02-09-2010 05:33 AM |
Superior Drummer 2.2.1 Crashing HD | ammaclean | Pro Tools TDM Systems (Mac) | 3 | 01-25-2010 09:31 AM |
Superior Drummer 2 crashing PT | Studio Dweller | Pro Tools TDM Systems (Mac) | 12 | 12-23-2008 05:17 AM |
