Going to buy a new Desktop PC, concerned with PT8 Vista Compatibility
To: Digidesign and members
I'm going to buy a Desktop PC within the next month or two and am concerned with Pro Tools 8's compatibility with Vista. Unfortunately, most computers now come with Windows Vista 64-Bit Home Premium installed. Digidesign says that Windows Vista 64-Bit (any version) is not supported with Pro Tools 8 1) Has anybody successfully installed and used Pro Tools 8 with Windows Vista 64-Bit Home Premium 2) Digidesign: Do you plan to fix this issue with Windows Vista 64-Bit? |
Re: Going to buy a new Desktop PC, concerned with PT8 Vista Compatibility
64 bit is NOT supported, even though some say they've made it work, it isn't very reliable and you're totally on your own with any tech issues on an unsupported o.s.
this will take a major re-coding, i.e. don't hold your breath. Not many people are recommending Vista, either. XP is the most stable in the majority opinion. Other issue....an off-the-shelf PC is NOT the best way to go. Better to get the proven parts and build it yourself. |
What he said!!
Check out the sticky threads for some proven systems that other DUCers have built. They'll give you a good idea of cost and even a list of components... BTW - You can get an OEM version of Windows XP Pro SP3 now for under $100. I'd recommend going with this until Windows 7 is out and proven stable with PT.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2 AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM www.wolfskinrecords.com www.voodoopilot.com |
What they said!
Even if you're not computer savvy, consider learning how to be. You'll be much happier knowing exactly what's going on by building your own system. If you really don't want to learn, get a PC from Sweetwater.com and at least you'll have technical support on it from them as well as from this forum.
Worship Leader * Producer * Guitar Man Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4 Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200 Eleven Rack (live rig and studio rig!!) Win7 * 003R * PT 11
Again, what they said.
As for the statement that most off the shelf computers are coming with Vista Home 64 bit preloaded, I haven't seen that. Most of what I see is Vista Home 32 bit. Vista 32 bit works with PT8. Although previous versions of Protools definitely worked better with Windows XP than Windows Vista (again 32 bit only), Protools 8 seems to have closed the gap. The general concensus is still that XP performs better (according to DVerb Tests) but still the gap is closing. Best Solution: Build the Protools Computer from known working components.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Vista Compatibility | asel | Pro Tools SE and Essential (Win) | 3 | 01-12-2011 05:09 AM |
Can no longer run Pro Tools LE 7.4/Mbox 2 on Vista Laptop or XP desktop | squat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2010 10:39 PM |
Vista compatibility | Jamesgug | General Discussion | 2 | 12-17-2008 08:29 AM |
compatibility for vista SP1 | chetorper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-21-2008 04:06 PM |
XP / Vista compatibility | MCL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-27-2008 04:20 PM |
