Export->Sibelius is disabled. why?
Howdy folks,
I rarely use VIs in PT, but decided to try working on a new composition in Xpand 2 today. Got the basics down and wanted to move to Sibelius for more complex orchestration. Remembering that PT & Sibelius are supposed to work well together, I went to the File->Export menu to export a Sibelius file, but it's greyed out! Any ideas why? I have the option to export MIDI (both in File/Export & in right clicking the instrument track), but not Sibelius. I'm running PT 12.5.2, Sibelius 7.5, macOS Sierra 10.12.6. thanks in advance ~peter
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: Export->Sibelius is disabled. why?
Bueller? no one else uses sibelius export, eh?
Sibelius is at version 8.7 now.
I bought Sibelius back at version 7.x. Never had luck with the rewire feature. Have not tried exporting back and forth for several years.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon |
Does anyone have the Export->Sibelius option in the file menu, not greyed-out? thanks in advance ~peter
From the menu, choose Window | Score Editor. Then, File | Export | Sibelius ... should no longer be greyed out. Regarding the "why?" part of your question, I don't know.
yes that's what i did, but it's disabled. thanks for the response...
Sorry to hear that. Another thing you might try would be to use File | Send to ... | Sibelius, which should be available in the menu when you have the Pro Tools Score Editor in the foreground. This command should launch Sibelius (if you don't already have it open) and display the score as a new document there.
I have the latest versions of Sibelius (8.7.0) and Pro Tools (vanilla) 12.8.1, and these commands work well on my system. I couldn't find your Sibelius version from your public profiler. The easiest way is probably to file a new case with Avid support. Good luck! |
Both "Send to" and "Export Sibelius" were greyed out until I opened the Score Window (had loaded a file with a MIDI track selected). With the "Score Window" open, I got both functions to work. "Send to" opens Sibelius whereas 'Export Sibelius" just creates a Sibelius file under whatever directory/folder you point to. However, after getting it to work, I noticed the functions were greyed out again. I got the functions back by pressing the space bar to start and stop playback.
I see from the list of bug fixes in 12.8.2 the following: "Using Keep Window on Top in the Score Editor no longer prevents use of the Export to Sibelius command (PT-231287)". Perhaps that indicates that the reason the function is not available might be that the user has "Keep Window on Top" checked in the top right dropdown menu in the Score Editor. I also found the following link to be an interesting how-to:
https://ask.audio/articles/pro-tools...-5-quick-steps |
In 12.4, the Score Editor must be the "active" window for the "Send to" and "Export Sibelius" functions to work.
Pro Tools Export to Sibelius | Rick3390 | Pro Tools 9 | 5 | 07-27-2012 11:43 AM |
send to sibelius, export to sibelius... | ericlees | Pro Tools M-Powered (Win) | 1 | 11-07-2010 07:17 PM |
send to sibelius, export to sibelius... | ericlees | Pro Tools M-Powered (Mac) | 1 | 11-07-2010 07:02 PM |
Sibelius First - export from PT? | table17 | MIDI | 1 | 11-03-2009 07:39 PM |
Export Function Disabled - Why? | gazblake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2007 01:30 AM |
