New external drive advice needed – G-Drive
Hi folks,
I’ve reached that dreaded point where one of my drives is filling up and it’s time to get a new one. My iMac has 2 Thunderbolt ports and I was hoping to take advantage of some (hopefully) significantly higher Thunderbolt speeds than my current FW800 drives can offer. I’ve got three G-Drives daisy-chained together right now, so I was thinking I might as well stick with G-Drive since they’ve done pretty well for me so far. (Haven’t had one fail on me yet!) I want 4 TB so it won’t fill up so quickly this time. It looks like my two choices are the G-Drive w/Thunderbolt or the G-Drive Pro w/Thunderbolt. Both come in a 4 TB option. G-Drive w/Thunderbolt. It says transfer rates are up to 226 MB/s. It only has one Thunderbolt port, and the other is a USB 3.0 port, which means it might make a faster daisy chain connection to my 2nd drive in the chain (my sample library drive) which also has a USB 3.0 port (along with 2 FW800 ports). Also, it’s significantly cheaper than the Pro. G-Drive Pro w/Thunderbolt. It’s just about twice as expensive as the other one (which I would be willing to shell out for if it’s the right one for me), but it boasts up to 480 MB/s speeds! Also, it’s got only 2 Thunderbolt ports and nothing else. So daisy-chaining to my sample drive would require going into the FW800 port on that 2nd drive. Significantly slower I would guess. Also, they say this one is RAID. I don’t know anything about RAID, whether I even can or should be using it for an audio drive with Pro Tools. Not sure if I wanna open that can of worms if it’s not necessary. I’m kinda leaning towards the first one (cheaper one). I guess the main questions are: Do the speeds really make much difference here or are the 480 MB/s speeds just overkill? (Especially since I’m on an Mbox 3 Pro which is only FW800 anyway.) And how does the RAID figure in? I read somewhere that I should avoid RAID (but like I said, I really don’t know anything about it, and that info may have been specific to a completely different situation). Any advice would be much appreciated!
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
Re: New external drive advice needed – G-Drive
Are you trying to start a computer museum? If you want performance why are you looking at HDD and not SSD? Why do you want to by a HDD RAID box like these? they are almost certainly not the way to go.
Get a good SSD for a working drive. Get a lower performance HDD for archive capacity. iMac has USB3? Samsung T3 USB SSD are a good affordable choice. LaCie make various thunderbolt SSD dives from the rugged range up to the Little Big Disk 2 Thunderbolt 2. If you want high end "Thunderbolt performance" you will only really get that with a PCIe based SSD (like the Little Big Disk 2 Thunderbolt 2). But Thunderbolt 2 is long in the tooth and Apple just is dawdling not shipping Thunderbolt 3 yet which is likely holding up a whole slew of intersting new external SSDs. Meanwhile PC users can spend a few hundred dollars and buy one of these performance monsters... http://www.amazon.com/Samsung-950-PR.../dp/B01639694M The Apple closed garden is looking pretty sad and underwatered right now.... Ah and no you can't chain a USB 3 drive to a Thunderbolt drive just because it also has a USB connector. Things don't work that way. |
The LaCie looks like an option, but the spec sheet says it's not as fast - 180 MB/s. Even the cheaper G-Drive says 226 MB/s. Quote:
No, the G-Drive has a USB3 port. That's why I was considering going Thunderbolt from the iMac into the G-Drive and then USB3 going out of the G-Drive to the next G-Drive. But, you're saying that won't work(?), so that changes things now considerably. Now I think I'm even more screwed.I had no idea you couldn't daisy-chain USB3 drives. I thought that, like with a Thunderbolt to FW adapter, you might be able to daisy-chain them but it would just go at the slower speed of the slower cable.
You talked about wanting fast and big. And that's somewhat a contradiction, well it depends on your budget. Which we have no idea of. If you want Thunderbolt and high performance then Lacie Little Big Disk 2 Thunderbolt 2 is a good choice, but getting long in the tooth. Or look at Samsung M.2 (esp. SM951 drives if you need it bootable) in an external PCIe enclosure if you want to play building something. More moderate performance is available from any number of SATA SSD drives in external encloses. Prebuilt like this one.. (http://www.lacie.com/products/mobile...ed-thunderbolt... see the "SSD" labels). Or a Samsung 850 Pro or Evo packaged yourself in a Thunderbolt tray or dock (e.g. Nice dock: http://www.sonnettech.com/product/ec...rboltdock.html). Given the performance available at great price on modern M.2 SSD drives it's just sad to think about how crippled the Apple Thunderbolt/storage ecosystem is. Also you say you do not have USB 3? A late 2012 iMac *does* have USB 3. So if you are just after SATA SSA type disk performance and some capacity and on a budget then, again, look at the T3 I pointed you at before.... http://www.amazon.com/dp/B01AVF6UHK/...ing=UTF8&psc=1 It's a well regarded Samsung 850 Evo SATA III drive inside that enclosure. Available up to 2TB. Nice portable, robust, and much faster than what you have now. if needed archive/move stuff to HDD as you finish with it. Buying a more expensive Thunderbolt SSD if it's only a SATA drive inside won't provide much increase in performance. Last edited by Darryl Ramm; 05-26-2016 at 11:54 AM. |
Thanks for the help BTW.
Oh, and another relevant question is: Is all this talk of speed and performance kind of useless if I still have just a FW800 interface (Mbox 3 Pro)? So does the FW bottleneck any speed advantages anyway that some of these faster drives are advertising? (Kinda like with how Pro Tools when it was still 32 bit, any RAM over 4 GB was pretty much wasted?)
C'mon you can Google most of these and anwer questions yourself. Find stuff on a vendor's web site and read their specs.
Lacie Little Big Disk 2 (LBD2) can daisy chain, it has two Thunderbolt 2 ports. I'm not going to insult you intelligence by providing a link to Lacie's product page that describes all that very clearly. LBD2 and all other Thunderbolt 2 storage devices are now long in the tooth and hopefully about to be replaced by Thunderbolt 3 devices. The LBD2 appears to being discontinued and I expect a new version will appear soon. But if you need high performance (better than SATA) *now* in a pre-packaged solution then it is likely the device to buy. What is "your sample drive" exactly? With exactly what connections? If its Firewire you connect it to a Firewire bus/adapter. If its USB you can't daisy chain it. Connect it to the iMac USB ports or use a USB hub if really needed (well put other slow peripherals on a USB hub). You can google JBOD and find what it means right? Software RAID (what the G-Tech uses) vs. leaving the drives in JBOD is set up in OS X disk utility. You can also Google you exact Mac model and find out what it has. System Profiler will report USB 2 and USB 3 devices on a iMac with "USB3" ports. Again since you seem to be struggling so let me make it easy for you... A late 2012 iMac *does* have USB 3. So if you are just after SATA SSD type disk performance and some capacity and on a budget then, again, look at the T3 I pointed you at before.... Disk performance itself always helps, independent of what you are driving the interface over. And getting Firewire disks off the same Firewire bus as an interface is always a good idea. It is not clear if you are doing that today or not. There is really no reason for most DAW users to buy a HDD when they could be using a much faster SSD (faster access times and sequential bandwidth, access times are what cause many DAW issues). |
Sorry, I know I'm being a pain. It's just that I did google a lot of this stuff and found that the more I was looking into this stuff, the more I realized I didn't know. And with so many different choices and technologies it just got more and more confusing really fast. A lot of these blogs & wikis don't necessarily explain this stuff in simple layman english so it sometimes helps to have it spelled out by someone who knows their stuff. Again, thanks for taking all your time here.
Anyway, I've decided yes you're definitely right. I need to get an SSD. I just have to bite the bullet and not worry about a large 4 TB size and just do a lot more archiving to make room as needed. (Should be a lot faster anyway than it is now with the FW800.) The only question I gotta figure out now is whether to go with the LBD2 or the Samsung T3. Quote:
So now that I know the USB3.0 is an option (going from my USB ports), I just have to decide whether to go that way (with the T3) or go with the original plan with Thunderbolt (LBD2). I just have to figure out whether I really can afford that one or not. I'm not so worried about it getting "long in the tooth" because, as mentioned, pretty sure my computer still is only TB1 anyway. So even with the LBD2 being TB2, I'm not able to take advantage of those speeds anyway. Thanks again for your help. I think I can figure something out from here.
Advice needed on hard drive | Cal D | Pro Tools M-Powered (Win) | 3 | 12-04-2015 06:26 AM |
MacBook Pro models for PT11+a 2nd internal drive-no external drive needed | VRW | macOS | 1 | 09-22-2014 01:35 PM |
External Drive Needed? | TerryBarnett | Pro Tools 11 | 13 | 05-26-2014 09:58 AM |
2.5" drive advice needed. noisy G-Drive Mini | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-17-2010 05:10 PM |
Advice on External Hard Drive needed.... | EDurney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-27-2007 07:09 PM |
