  #21
Old 11-30-2014, 11:37 AM
rdobra rdobra is offline
Default Re: S3L Venue Link trouble
Right, without doing anything different then in my previous attempts to get VENUE link working, it does now show in Setup/Peripherals/Venue as connected. I can drop markers now in Pro Tools via snapshots, I can arm, record enable, start recording, etc but I cannot create session from VENUE or import track names. It gives me this :
by selecting the option - Create Session from VENUE - '' There are currently no interfaces in I/O Setup which are known to be connected to VENUE ''
  #22
Old 12-01-2014, 02:51 PM
Mike Z's Avatar
Mike Z Mike Z is offline
can you check to make sure the TCD/UPD setting is set to the default value of 29292 on both the S3L and the Pro Tools computer in Setups>Peripherals>VENUE?
Let us know!
Thanks,
-Mike
Avid Live Sound Support
  #23
Old 12-02-2014, 12:01 AM
Hi Mike,
both VENUE and Pro Tools are set to 29292.
At the moment, creating a session from VENUE or Importing tracks from VENUE are leading to this dialog - '' There are currently no interfaces in I/O Setup which are known to be connected to VENUE '', everything else in VENUE link is working as expected.
Thanks,
Radu
  #24
Old 12-02-2014, 02:01 AM
pmueller pmueller is offline
Turn off FireWall and WI-FI by starting Protools.
This may help.
Best, Patrick
www.tonkultur.ch - remote recording services
  #25
Old 12-02-2014, 05:04 AM
jacko's Avatar
jacko jacko is offline
I made this video presenting the problem:
https://www.youtube.com/watch?v=MJMBODlRGDY
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #26
Old 12-02-2014, 03:56 PM
Mike Z's Avatar
milaswewski,
Can you show us a picture or describe the settings for the Ethernet Connection in System Preferences>Network?
This should be set to DHCP and should show the same IP address beginning with 169.
Also, what do you see in the Pro Tools IO setup?
Thanks, and be sure to restore the default TCP/UDP setting of 29292 on both systems.
let me know,
-Mike
  #27
Old 12-02-2014, 04:17 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Try this:
1. Set Pro Tools to default TCP/UDP 29292
2. Set VENUE system to default TCP/UDP 29292 (options>interaction)
3. Shut down and reboot the VENUE system
This has worked for me in a similar situation.
Sheldon
  #28
Old 12-03-2014, 12:07 AM
jacko's Avatar
Originally Posted by Sheldon Radford View Post
Try this:
Sheldon
Thanks a lot! That worked! I actually tried steps 1 and 2 yesterday and it didn't work. I shut the console down and left it there for the night. This morning I looked at your post and first I thought "I've already tried that" but then I realised I did not reboot the Venue. It worked straight after I booted it this morning. Thank you!
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #29
Old 12-03-2014, 01:01 AM
Valentyn Valentyn is offline
Wow! And now I know why this happens
  #30
Old 12-03-2014, 06:58 AM
So, to summarize:
Venue Link port setting needs to be kept at 29292 (default value) in VENUE 4.5.0/4.5.1 in order to establish a connection to Pro Tools.
Having trouble getting SC48 to work with Venue link on alternate network interface blantonlew VENUE Live Sound Systems 2 07-12-2013 11:36 AM
Venue link (inactive) kurt-jen VENUE Live Sound Systems 1 09-29-2011 08:15 PM
Venue link issue digidesigner VENUE Live Sound Systems 13 07-19-2011 06:44 AM
Venue Link and VNC mariojorgeandrade VENUE Live Sound Systems 2 11-16-2010 08:27 AM
Cannot link Venue SC48 to laptop with FWx jmillgrip VENUE Live Sound Systems 7 03-24-2010 01:05 AM
