Old 04-12-2010, 09:18 AM
Chris4metal Chris4metal is offline
Exclamation Pro Tools doesn't start
Hey, I just installed Pro Tools v7.4 M-Powered on Windows 7 Ultimate because I also just bought the M-Audio Fast Track Pro and I wanted to find out what Pro-Tools can do. But my problem is that while Pro-Tools starts normally and starts loading things, it freezes when saying "Setting Up MIDI"... I tried everything... I uninstalled the program and reinstalled it about 2 or 3 times as well as the M-Audio drivers, too... Please help!! I am trying to fix it about three days and I feel like I threw my money away...
Old 04-14-2010, 09:55 AM
Default Re: Pro Tools doesn't start
I'm so happy that NOBODY is helping me... And this is my first post... Very nice forum... Thank you all... Much appreciated...
Old 04-14-2010, 10:05 AM
scenicrecords scenicrecords is offline
Only Pro Tools 8.0.3 is compatible with Windows 7, and it is still in BETA. It has many issues. I would recommend installing Windows XP with 7.4.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 04-14-2010, 11:37 AM
Thank you very much for your response!! Well, Pro Tools starts fine I think, but it sticks when saying "Loading MIDI"... Even if it's not compatitive with Win7, there is a "trick" on Win7, where you can run any program via any kind of windows... If you right click on Pro Tools' icon for example, and you go to "properties", you can change the compatibility of Windows, and make it run via Windows XP for example... I am not sure if you understand what I'm talking about, but this isn't my point (look up on the web for more about this "trick" on Win7)... Anyway, can you help me find the problem? I have installed more recording programs as well, but all stick when saying "loading MIDI" or "loading Plug-ins" or they do not even start... All my drivers are perfect and updated, as well as my settings...
Old 04-14-2010, 11:46 AM
Pro Tools is very picky about having everything setup exactly right. It took me months to get my system stable enough to work. Running it in a compatibility mode may work briefly, but you could run into many problems down the road.
I started with Win 7, PT 8.0.3. I am now on Windows XP PT 8.0.1cs1 as it is the most stable release. I would recommend going through all the recommended setup options in the stickies and what Digi recommends.
Post a Sandra report too - this will help identify any hardware incompatibilities.
Windows 7 64-bit
Old 04-15-2010, 05:13 PM
Julia B Julia B is offline
I'll second the 8.0.1 cs1 w/ Windows XP SP3. I tried the 8.0.3 cs2 on WinXP and it didn't work well. Of course there's no point for me to update either since I use neither Win 7 or IE 8.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
Pro Tools won't start up? calicobumps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-26-2010 09:28 AM
Pro Tools will not start up. Help khenninger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-12-2007 03:51 PM
Pro Tools won't start on my Mac Ralph Baumgardner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-11-2007 02:24 PM
Pro Tools 5.1 Session Start—Record Start Interval Avid Pro Tools TDM Systems (Mac) 4 04-18-2001 08:27 AM
