elastic audio - corrective work flow
i use elastic audio to manually pocket vocals
i go through each region (usually one per line) and delete all analysis markers then i switch to warp view and add warp makers at the beginning of sylables where i see fit then i move the warp markers to grid (super pocketing of vocals) what i do next is up in the air, im not super sure of the most efficient method yet... should i keep pocketing and then at the end xform the whole thing? this is sort of scary because there might be a line or two or even ten that you'll want to change and its a a bit of a pain to keep doing this over and over. especially when disabling elastic audio on the track commits every region in the track, not just select regions if i don't do it that way, whats the best way to make the x-form commitment? it seems like you'd have to switch to x-form mode, wait for render, then switch off elastic audio and hit commit, then switch back to real-time to keep working on other regions on the track another idea i had was to make an x-form track, its empty, and you just cut / paste the take from the real-time elastic audio track to the x-form elastic audio track. this way, your edits are instant, and you can make changes quickly and when you're satisfied, you can easily commit to x-form in a couple of key strokes... the annoying thing is that even after this you still have to copy and paste to a regular audio track because copying and pasting back into elastic audio track will keep the elastic audio information online. (i am wanting to make completely committed audio) and im not sure how i feel about consolidate regions. the manual doesn't really tell you whats happening in terms of elastic audio data... like if it re-renders the audio or what... hopefully someone understands what im talking about here and can offer some advice or their experience... im on pro tools hd! thanks! |
Re: elastic audio - corrective work flow
Good luck, |
Elastic Audio won't work? try this | 77pro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-03-2014 06:21 PM |
Help Elastic Audio will not work properly | OnTrak | macOS | 2 | 04-18-2012 08:06 AM |
Why won't elastic audio work in PT8..? | jtrainer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-26-2011 07:12 PM |
Elastic Audio work flow question | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-29-2009 06:57 AM |
Cannot get Elastic Audio to Work on Mac Pro PT 7.4 | Khaarmeyer | Pro Tools TDM Systems (Mac) | 4 | 11-22-2007 09:06 AM |
