Old 11-14-2006, 05:54 PM
vseus vseus is offline
Default Instrument Tracks Produce Hiss
Can anyone tell me why this is? With some heavy compression and limiting it is fairly obvious.
Old 11-15-2006, 07:44 AM
Default Re: Instrument Tracks Produce Hiss
Old 11-15-2006, 08:04 AM
DigiTechSupt's Avatar
You will need to provide more information than this for us to help you. What VI are you using? What are you system specs? What troubleshooting, if any, have you tried?
Avid Audio Tech Support
Support FAQ
Old 11-15-2006, 12:04 PM
I have a 002 rack, but I think this is a software issue. Anyway, maybe it's just me that has this problem:
Start a new session.
Create a stereo Instrument Track.
Create a master track.
Turn up the instrument track volume to 0.
Now turn up your monitors to full gain and see if you can't hear white noise.
Mute and unmute the instrument track and you can hear the noise definitely coming from the intrument track...or is it just my system that does this?
Either way this really raises my noise floor a substantial amount.
Old 11-15-2006, 12:07 PM
spkguitar's Avatar
What audio input do you have selected for the Instrument track? Is there anything actually plugged into it?
Old 11-15-2006, 02:09 PM
Aha! It's the audio input. When I set it to 'no input' I hear no hiss.
The weird thing is it doesn't do this with audio tracks, only instrument tracks.
Thanks for the brainpick spkguitar.
Old 11-15-2006, 03:42 PM
spkguitar's Avatar
There are some VI that require a valid input be selected for the audio input, but from what I understand from Digidesign, this is an indication that the plugin is not 7.x compatible.
Also, from the getting started guide:
Engage the Mic selector only if you have an
XLR cable plugged in to the mic connector.
Leaving the switch engaged with nothing
connected may introduce low-level noise.
So if it's necessary to select an input for a plugin that you are using, make sure that the mic selector is set to line, or that you select one of the inputs that does not have a mic pre.
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
003 and Eleven Rack - Digital hiss when rec arming SPDF tracks kkguitar macOS 1 10-11-2011 09:42 PM
Hiss on all tracks after import cbwhitebu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2010 07:58 PM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
Need plug-in to reduce hiss on tracks - advice too gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-21-2005 09:12 PM
