Re: UAD 2 Quad and GA-EX58-EXTREME
akhafaji
The GIGABYTE motherboard spec states "(Note 3) The PCIEX8_1 slot shares bandwidth with the PCIEX16_2 slot. When PCIEX8_1 is populated with a PCI Express graphics card, the PCIEX16_2 slot will operate at up to x8 mode. " Since, I believe, you have your HD Native card seated in PCIEX16_2 (the blue slot right next to the video card) I think seating the UAD-2 card in the PCIEX8_1 slot (the long orange one) might be ill advised as it would be sharing bandwidth with your Natve card. So yes, move your UAD-2 card to the PCIEX1_1 slot (the short white one) and give that a try. |
Aaron Mulqueen - 001 HD Native |
http://www.gigabyte.com/fileupload/p.../2957/1046.jpg http://www.gigabyte.com/fileupload/p.../2957/1049.jpg I am not sure if this part in PCIEX1_1 slot is mandatory (I think it’s related to the cooling system with the motherboard, can I remove it?) if I can't remove this part , can I use the long white slots? GA-EX58-EXTREME - Link: http://www.gigabyte.com/products/pro...px?pid=2957#sp Thx |
akhafaji, seat the UAD-2 PCIe card in PCIe x8 slot 1. The orange slot at the end. Screen Capture
Note 3 only applies when there is a graphics card seated in PCIe x8 slot. (Note 3) The PCIEX8_1 slot shares bandwidth with the PCIEX16_2 slot. When PCIEX8_1 is populated with a PCI Express graphics card, the PCIEX16_2 slot will operate at up to x8 mode. So you should have PCIe x16 slot 1 (blue) Graphics card, PCIe x16 slot 2 (blue) Native card and PCIe x8 slot 1 (orange) UAD-2 card.
akhafaji
it was my understanding that the UAD-2 card was already seated in the PCIEX8-1 slot (the long orange one) and that there was a problem or did I miss something? If that is the case you could try seating your UAD-2 card in the PCIEX4_1 slot (the short orange one). I would leave the radiator seated in PCIEX1_1 where it is. Do not remove it. The long white slots are PCI slots. I wouldn’t recommend seating a PCIe card into one of those. I think the PCIEX4_1 slot is the only option left so hopefully that works. |
#16
I did that but the issue still the same. |
#17
you are correct UAD-2 card was already seated in the PCIEX8-1 slot (the long orange one) the issue that the radiator blocking the way so I don't have space for the UAD 2 to be in PCIEX4_1 slot. |
#18
akhafaji, are playback errors -909x present after removing UAD card?
#19
That radiator looks very cool but it is also very greedy by taking up two PCIe slots. What exactly is its purpose? I've only ever seen rigs like that in gaming computers. It's all a matter of priorities of course but it may have to go to make room for the UAD-2 card.
Why not temporarily remove the radiator and then seat the UAD-2 card to see if it solves your Pro Tools problem. If it does then you'll have to decide whether you want to keep the radiator or use the UAD-2 card. |
#20
I've just had a second look at the pictures and temporarily removing that radiator might not be be so easy. It is also potentially dangerous as it may cause overheating issues we don't know about. I'll let you be the judge but you may want to consider other alternatives first.
filosofem had an excellent question, do you get the same errors after removing UAD card?" |
Mem Upgrade for GA-EX58-UD3R Mobo | lowlights | Windows | 0 | 09-11-2012 11:06 AM |
Gigabyte GA-EX58-UD3R and hd system | dccarson | Pro Tools TDM Systems (Win) | 0 | 10-30-2011 03:45 PM |
HD card for Gigabyte GA-EX58 | jcolagross | Pro Tools TDM Systems (Win) | 1 | 09-07-2011 05:42 PM |
Pro tools HD and GIGABYTE GA-EX58-UD3R | KKalampo | Pro Tools TDM Systems (Win) | 4 | 04-07-2010 11:26 PM |
if you have a Gigabyte EX58-UD3R motherboard please help me. | recordingguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-19-2009 09:09 PM |
