Old 06-08-2010, 07:08 PM
boynigel boynigel is offline
Default "Digi Hardware not found" mesage
i'm running PT 7.3.1 on an intel imac via mbox 2 pro. lately, every time i go to boot PT, i get a message that says, "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready."
i can fix this by pulling the firewire cable out of the back of the computer and plugging it back in. i thought maybe the firewire port on my computer was bad, but then i found that this trick also worked if i pulled the firewire cable out of my mbox. what gives? this even happens when i try to run itunes.
Old 06-09-2010, 04:33 PM
Default Re: "Digi Hardware not found" mesage
bump, anyone?
"Hardware Not Found" Mbox mini 3rd gen Anderson27 FireWire & USB Audio Interfaces (Mac) 20 05-04-2017 02:32 AM
Pro Tools 10 standalone and "hardware not found" Windcruiser Windows 3 11-17-2012 01:56 AM
"hardware not found"...power light solid. cjdude macOS 16 05-28-2012 01:05 PM
Mbox Mini Lights up but "hardware not found" gramtsupak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-05-2011 09:07 PM
Mbox mini installation problem - "Hardware Not Found" tinsoldierman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-18-2010 03:06 AM
