#6001
Re: Best Desktops for PTLE
Hi all. After reading many posts and considering my budget I have decided to build my own system that I feel comfy with. Feel free to let me know of potential problems if you see any.
Here goes... Just about to build> Antec LS100 case Gigabyte Odin 550w PSU ASUS P5Q Pro Mobo Intel Q6600 2.4GHz CPU Palit 8400GS vCard Corsair 2GB 2048-8500 800 Mhz DDR2 SDRAM Behringer Ultra Curve Pro 8024 Digi 002Rack 32-bit Windows SP SP3 REASON v3 (will upgrade to v4) SampleTank 2 (may abandon this??? any thoughts) Protools v6.7 (will upgrade to v8) Garritan Personal Orchestra Garritan Jazz Orchestra Audacity (for recording loops, samples, small edits) Yet to purchase Seagate SATA II HDD 250GB (Programs) Seagate SATA II HDD 500GB (Music files etc) 2x 19" Samsung LCD screens powered monitors (any recommendations for starting out - ie best for cheapest price. Will upgrade later but for now could possibly correct - if shown how- with Behringer Ultra Curve Pro 8024) LG??? DVD RW (I think I could save money by not purchasing Blue ray just yet - considering I mainly burn Audio CDs anyway) Last edited by Craeon; 02-10-2009 at 12:49 PM. Reason: spelling |
#6002
hey man your scaring me! haha I was under the impression you were using the on board gigabyte firewire.....have you tried it? I didnt order a card cause I thought the on board one would work....hmm
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
#6003
the onboard from what i understand has the correct chipset and should work, but i had this card from my last build and since i knew it worked i just put it in and shut off the onboard firewire. if i get time later maybe i will give it a try and see what i quickly find. but havent checked but if you are here in the states you gotta have a best buy nearby!
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#6004
Very true haha I actually just bought a red led illuminated keyboard from there last night to match my red led case haha I guess if worse comes to worse I can fly there and grab one
#6005
Hello, I am new to this forum and want to purchase a Digi 003 rack +factory. I am looking to buy a Dell PC to do my recording with. I've never really used a Mac and would rather use a comp that i'm comfortable with. If I buy a brand new Dell which goes well above the standard system requirements will I have a problem working with Pro Tools comfortably?
#6006
I am new to this forum and I need some assistance. Here is my situation: I want a low cost PC to run PTLE 8 with a Mbox2 via USB. I am not looking for maximum track count. The max I see myself needing is 24 tracks. Most of the time I don't expect to need more than 12 tracks. I don't need the latest graetest, bigest badest box on the block. I just want to do some simple recording, without too much hassle during the process. Can I do the job with a pentium 4? I want just enough PC to get the job done effectively, without overkill.
Any sugestions for a system? I am okay with building my own or buying a pre-made system, whichever is most cost effective. Last edited by DigerEdo; 02-18-2009 at 08:11 PM. Reason: Fix gramatical errors |
#6007
With these economic conditions, I was wondering what the most cost effective system would be at this time ?
Thanks, Logan |
#6008
#6009
If you are using Digi 001,,, a P4 works really well,,,, but if you move up to Le 7.4 or Le 8.0,,,, you will deffinately need more power!!!! I loved my 001 and P4, but it was time after many years to upgrade,,, and the difference is well worth it, once you get used to it!!! But a P4 will bog down 'A LOT' with the 003, and probably the 002's?? Get yourself a Duo with 2 internal drives (7200 RPM) and you'll be happy!!
Hope this helps ,,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
#6010
It's not the track count but the effects and VSTi that are killing it. I've gotten many fine years out of this box, but it's time to move onward and upward. BTW I have seperate 7200RPM drives and 2G memory. The bottleneck is the CPU on my system (P4ht 3.0ghz) I'm in the process of upgrading as well and will be buying the parts in the next couple of weeks. |
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
