#5991
Re: Best Desktops for PTLE
Originaly by chaos6403
If there is anything else worth reporting You can be sure I'll let you all know! PS--- downloading PT8, Waves plugs, MP Toolkit, and all, went without a hitch,,, simply download and play!!!! Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
#5992
hi pianoman
why did you go for the Corsair 750 W PSU,, when the case comes with standard 450W supply? any results with big racks of VIs including strike? cheers rikttt
PTLE8.x Mbox, Sibelius, Record, Reason, i7 D0, UD3R rev1.6, GEIL 6GB KIT EVO ONE C9 2000Mhz, Noctua NH-U12P SE1366, CavBlacks 2x 500G + 1xT, SAPPHIRE HD 2400PRO 256MB SILENT, CORSAIR 750W, Novation Remote SL37, Win7. . |
#5993
i ran my i7 in my first session last night, tracking at all 64 with no probs. i am using an pcie firewire card. stock one from best buy, an siig i believe. might be worth looking into.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#5994
I messed around with strike, structure, and a few others,, all work fine, but being an older guy (not all that old),, I'm very used to the keyboards and rack sound modules that I have used with PT back when the 001 1st came out. The only VI that I have found to have the quality I need is Synthogy's Ivory,,, which is just piano. But I'll have to admit, the sounds that I'm hearing with these VI's that came with PT8 aren't bad at all??!!!! I might actually have to put them to work on a few projects,, and see what they actually can do! Quote:
Anyone with RAID knowledge have any suggestions, what am I missing?? Also, Ive been following (in my spare time) your posts below (guitardom) and noticed you mentioned, I think, the need to set your RAM speed in the BIOS. Mine is set at auto??!! Which I assumed would be fine???? I'm running 1600 triple channel,,, thanks for any thoughts,,,,,, Mike
#5995
Another questian on firewire,,,,,,, PT needs firewire 400,, correct? would 800 work,, or is this a non issue????
Thanks ,,,,,, Mike
#5996
set it to manual and the speeds should pop up if you cant see them now. you should have setttings like 5-5-5-20, and your voltage say 2.1v (not 100% yours is 2.1, should say in the manual, or check the specs in newegg and will tell you this info. need to check to see if these are correct, as well as it should also say 1600 for dram speed. if not might need to up the multiplier to get it to this speed. all this info should be easily found in the manual if you cant figure it out. i am not 100% about the pci having to be firewire 400 or if 800 or not. i think firewire 800 might be fine (backward compatible) might better off to have mykhal or someone answer this question.
#5997
Hey pianoman,
I'm gonna build your rack with the standard 450W PSU, if anyone can volunteer the reasons why a 750W Corsair would benefit me, please explain. Also gonna run 1xTB HD for Audio and 1x smaller for OS. Can't see why I'd need more - I'm getting by with 40G + 180G now on old P4 setup - just need more Ram with faster processor. Cheers. PS - you'd think that it would be in DIGIs best interest to recommend a stable setup for each release of PT - ie - "we have found that PT8 and common associated programs work well with these 4 chip/RAM/MOBO/Vcard configs for PCs... and these 4 configs for MAC..."
#5998
Hey pianoman,
I'm gonna build your rack with the standard 450W PSU, if anyone can volunteer the reasons why a 750W Corsair would benefit me, please explain. Also gonna run 1xTB HD for Audio and 1x smaller for OS. Can't see why I'd need more - I'm getting by with 40G + 180G now on old P4 setup - just need more Ram with faster processor. Cheers. PS - you'd think that it would be in DIGIs best interest to recommend a stable setup for each release of PT - ie - "we have found that PT8 and common associated programs work well with these 4 chip/RAM/MOBO/Vcard configs for PCs... and these 4 configs for MAC..." PT7.4 Reason4 Novation Remote SL Intel P4 2GRam WinXPSP2
#5999
Good luck,,, Mike
#6000
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
