Eleven rack problems with Imac
Help!
I have a eleven rack that I have used stand alone and as a audio interface with windows 7 with no issues. I am running Pro tools 10, the latest rev. I loaded Protools 10 on a new IMac running the latest rev of lion os. I was using a audio kontrol interface with no problems. Today I disconnected the interface, shut everything down, connected the eleven rack to the Mac turned everything on and started the Mac. When I started pro tools it does not recognize the eleven rack as a audio interface. It does not show up as hardware in pro tools setup nor will it record the guitar. It does start up the eleven rack control panel. My Mac has everything turned off as suggested by protocols manual. I have tried everything and am lost. Is there a seperate driver for the eleven rack? Any suggestions? |
Re: Eleven rack problems with Imac
Darryl |
How do you look at drivers on a imac? And how come the driver wasnt installed when I installed protools 10?
You don't need to look at anything. You down load the Eleven Rack driver package from Avid (a .dmg disk file), open that and double click on the installer (.pkg) file.
Darryl |
ya this is fixed. Thanks
Eleven rack Live problems. | Angelo Bruschini | Eleven Rack | 0 | 09-18-2013 08:49 AM |
Eleven Rack Problems | hero12300 | Eleven Rack | 8 | 06-26-2012 10:14 AM |
Problems using eleven rack with cab | rootyjooser | Eleven Rack | 3 | 06-19-2011 01:20 PM |
Eleven Rack compatibility problems? | fastnboulbous | Eleven Rack | 0 | 03-24-2011 07:08 AM |
Advice: iMac i7 + PT9 + Eleven Rack? | GanB | macOS | 1 | 02-18-2011 11:59 AM |
