Old 05-23-2011, 11:41 AM
whoever whoever is offline
Default Re: Euphonix Mix Connection Issues
Hi Mike,
Try going back to version 2.5.5. of Eucon. This is the only thing that works for me. 2.5.6 and 2.5.7 seem have a lot of bugs, particularly where Logic is concerned.
I've tried all the suggestions from support as well, but none of them have worked. I get endless problems with Logic, including crashes, spinning beach balls, Blank screen on my MC transport, soft buttons staying lit when they should be off, etc, etc.
http://www.ianshawmusic.com
Old 05-23-2011, 04:00 PM
mikenewport mikenewport is offline
Hi -
I just tried disabling wireless connection and it actually worked fine! No error message... Enabled it, turned Euphonix on and got the error. Checked again, and with wireless disabled it finds the mix and connects fine!!
So this seems pretty positive...what would you suggest I do to have wirelss enabled and it working?
Mike
Old 05-25-2011, 04:06 PM
DigiTechSupt's Avatar
This sounds like exactly what happens when Airport is not the top item listed in the Network system preference panel.
Can you double check that?
Avid Audio Tech Support
Support FAQ
Old 05-27-2011, 12:41 AM
Thought you might be onto something there, but checked and Airport is the top listed item in network prefs!
M
Old 05-31-2011, 03:00 PM
Interesting. Given the info you've provided, this would seem like a system-wide problem with network settings. I'm not absolutely certain about where to go from here - it could be a system preference file needs to be trashed or it could be an OS service that's corrupting things.
At least those seem the most likely given the info. Since it seems to work at first with the new admin account, but then gets 'corrupted' and returns to the dysfunctional behavior my only recommendation at the moment is to disable Airport while working with Eucon. I know it's a pain, but I'll need to look into what else could be done to solve this.
You may consider doing an install of the Mac OS X Combo Update for the OS version you currently have installed, as doing so has fixed similar situations for other customers in some cases.
Support FAQ
  #16
Old 06-08-2011, 05:22 PM
Ok, i'll try a combined update now and cross fingers! Please let me know if there's any other things you can think of to try as I do need Airport on really whilst composing.
Thanks for your help so far!
Mike
  #17
Old 06-09-2011, 04:22 PM
Yup no joy i'm afraid, have done a full update - Also just tried variations of the IP address from those suggested on Avid website, tried other combinations of using DHCP etc and no luck at all - I'm totally stuck!
M
  #18
Old 06-10-2011, 01:08 PM
Mike - give me a bit to look into this further, as it appears it's going to be more difficult than I thought. I've got a couple other priority cases I'm working on at the moment, but will get back to you as soon as possible.
Support FAQ
  #19
Old 06-10-2011, 02:16 PM
OK, thanks very much - I'll look forward to hearing your next thoughts on it!
Cheers,
Mike
  #20
Old 07-10-2011, 09:48 AM
rada113 rada113 is offline
Could you please explain which two soft keys need to be pressed ,while pushing power button to enter MC MIX IP setup menu?
Its not very clear from the manual!
Many thanks
Firewire connection issues Funkey1 macOS 6 07-05-2012 07:41 PM
Euphonix Mix Connection Issues mikenewport Artist Series 0 05-16-2011 04:22 PM
Connection issues charraig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-17-2011 04:50 PM
UPS/USB connection issues Armando Pro Tools TDM Systems (Mac) 0 01-03-2005 04:15 PM
Digi002 connection issues. IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2004 11:47 AM
