Old 04-02-2011, 03:46 PM
tommydigiowen tommydigiowen is offline
Unhappy Vocal Comp or Vocal Limiter?
Can someone give me the nutshell difference between VOCAL COMP & VOCAL LEVELER (compressor)?
Thanks!
T
Old 04-02-2011, 08:45 PM
Default Re: Vocal Comp or Vocal Limiter?
Generally, the difference is the ratio of GR. 2:1 up to 10:1 is compression. Higher ratios are considered limiters. Which to use depends on the audio. I go thru my lead vocal tracks and use the AudioSuite GAIN plugin to level out the performance9lower the really hot regions and boost the really weak ones). That way, the track hits the compressor more evenly, which can make the vocal sit better in the mix. Lately I have been chaining 2 compressors on my lead vocals. My usual chain is: EQ III one band(high pass around 140HZ), BF76(4:1 with light GR), EQ III 7 band(general tone improvement), SMACK!(more compression with some character) and a Pultec EQ1A to restore the "air" that sometimes gets lost(the Pultec does "air" like no other EQ I have found). I only use a limiter on a vocal if its really all over the map in level(which just happened on my latest mix project; which was recorded at another studio).
Old 04-03-2011, 02:49 PM
The Dougfather The Dougfather is offline
Check out this Sonnox Dynamics Video.
It shows the guy talking about using a Comp and Limiter together and there are examples.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 04-03-2011, 06:34 PM
Awesome..!
How to Import a Comp Vocal into ProTools tha]-[acksaw Tips & Tricks 3 07-23-2011 11:31 PM
Anyone vocal comping with the new comp feature? PhilBuckle Pro Tools TDM Systems (Mac) 3 12-22-2008 10:03 PM
Comp Settings For Jazz Vocal Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2004 01:47 PM
Fave vocal comp plugin hitp Pro Tools TDM Systems (Mac) 3 10-06-2003 11:24 PM
Vocal Expander Gate with a Comp. Sounder Tips & Tricks 1 03-12-2001 03:54 PM
