Defrag ?
Trying to use Norton 6.0 on my G4 Dual Processor
running 9.2.2. I'm trying to defrag my system disk(it's new but say's it's severly fraged) I boot up from the CD, but my system hard drive is nowhere to be found. Do I need a newer version of Norton or what? Also have seen other user's wary of using Norton on the system drive, are there any good reasons for this. My system is working fine, I only use it for PT(no web or e-mail). We had everything installed by the company we bought it from. I have only added Roxio Platinum Toast. Can't see how the drive got so severly fraged" |
Re: Defrag ?
I believe it's best to *only* use the boot drive to hold programs and the operating system, not session files or sound files. With that in mind, if you are encountering a lot of fragmenting on the boot drive, then do this: 1) back up the drive! 2) boot from the back-up. 3) run Norton Speed Disk (or Tech Tool or any other good defragmentizing program) 4) defrag the drive 5) boot from the original drive. All should be fine. Note that if you really want to, you can quickly de-frag just by copying all files to a new drive. But then you'll almost definitely run into copy-protection issues, for the same reasons given above. I have no idea why booting from Norton's own CD-ROM won't let you see the original boot drive. There are Firewire issues with 9.2, so if it's a Firewire drive, that could be one cause. But there should be no problem at all with internal IDE drives. Note also that it's really not a big deal to have fragmenting on the boot drive in the first place. You're not accessing the drive that much that it's really an issue, at least with ProTools, assuming all your session and sound files are on other external drives. --Marc W. |
Re: Defrag ?
Defrag? | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-14-2003 08:07 AM |
defrag | Veal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-02-2002 04:49 AM |
defrag | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-11-2002 12:58 AM |
best way to defrag... | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-13-2002 12:55 AM |
defrag Q | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-02-2001 12:46 AM |
