#31
Re: Pops noise after quick punch. Pics included.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#32
I'm seeing this issue now. Didn't show up until I started tracking bass guitar. I guess it's probably happening with other stuff but it just goes unnoticed unless you have constant low frequency info. I'm just stunned that a pro DAW would write an incorrect waveform to disc. A dozen extra pencil redraws per session is not all that time consuming. But it just makes you wonder, if it's altering your audio here, where else is it doing it? Very very bad news.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#33
I'm having the same problem, also started noticing it upon upgrading to Windows 7 64-bit. Is anyone noticing this in a _different_ OS?
#34
I've just learned to live with it and work around it by punching in and out way earlier and later than I normally would. Otherwise, it busts my groove. My eyes are going to get stuck in the rolled position if Avid doesn't fix this soon.
#35
bump. been getting loud pops after hitting stop sometimes when printing mixes. using hd3 with pt 8.1cs2 on snow leopard - no peripherals at all.....
#36
does anyone still get this in PT 10? I'm getting it on 2 different interfaces. ADC off, seems to be when doing a manual punchout. (in quick punch).
PT 10.2
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache |
#37
bump
#38
Has this issue been resolved?
I've been dealing with it since version 8, and it's still present in PT10.
Music Is Life |
#39
I have found a way to fix some of the problems with punch ins that cause click or pops. Use a fade on one or both segments that touch each other (where the click is heard). Sometimes this will eliminate the problem but sometimes it doesn't. I'm not a Pro but I've been slowly learning some tricks.
Peace |
Quick punch crack and pops update | jeam25 | Windows | 2 | 09-24-2011 07:44 AM |
routing question pics included | psychoth | macOS | 3 | 02-15-2011 02:32 PM |
Pops on every quick punch in 8.0.4 | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 10-05-2010 09:44 PM |
Quick punch problem creates pops. | Final Score | Pro Tools TDM Systems (Mac) | 0 | 09-07-2010 10:40 AM |
CLick noise when i quick punch | toofly4asoundguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-01-2004 03:17 PM |
