Old 06-09-2009, 02:51 AM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
Default Best Video Solution for Pro Tools
I was wondering what is the best video solution to use for my studio's Pro Tools setup. Right now we have PT LE 7.4.2 installed, with plans to upgrade to version 8, as well as upgrade to Pro Tools|HD. Please keep this in mind.
The workstation that we are using are the Mac Pros (Second Gen, Pre Nehalem). This system will need to hook up to two video monitors. Here are some options that I have came up with.
1. Canopus ADC-110
Actually have this system already. There is one output on it. Most likely need a distributor on it. The only real flaw is that I have to convert and transcode videos in a Quicktime DV format. If anyone has a suggestion on software, let me know.
2. Avid Mojo SDI
A popular choice. I have heard this has problem reading some Quicktime formats, and that it sould be converted to Quicktime DV25 file.
3. Avid Mojo DX
The new kid on the block with powerful hardware. A very expensive option for just outputing video from PT, and may be overkill.
4. Blackmagic Design Decklink SDI, Decklink Extreme HD, Intensity
A very cost efficent desicion. Has HDMI on the latter two cards, which allow for HD monitoring. Downfall is that there will be a less card slot when upgrading to PT|HD.
5. Video Satellite option.
Requires a Windows-based Computer with either a LE system, Blackmagic Design card, or Avid Video Interface installed. Needs Avid Media Composer 3.1. Researching this as a option and might be the best for my setup. What is the best configuration for this? Please let me know. I don't know how much it cost for the regular Video Satellite. I know the LE option is about $300.
All ideas are welcome. Please let me know what is your setup and please give me some advice on the best way to go about this. Thank you.
www.M-ManLA.com
www.facebook.com/MManLA
www.soundcloud.com/m-manla
Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro
Old 06-09-2009, 02:59 AM
tj_davies tj_davies is offline
Default Re: Best Video Solution for Pro Tools
1. Canopus ADC-110
2. Avid Mojo SDI
3. Avid Mojo DX
Kind of depends on what type of work you do. We work mainly on commercials - so no longer than 60". This means converting to dv is neither a time nor a storage problem. We have Canopus boxes in each studio connected to distributers to get it into the recording room and several televisions in the studios.
Hope this helps,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 06-09-2009, 03:38 AM
M-ManLA's Avatar
Hope this helps,
Timothy
Thank you. Anyone else?
www.M-ManLA.com
Old 06-09-2009, 03:52 AM
pezking pezking is offline
The black magic cards are certainly a great solution.
If you're worried about losing a slot on the computer - consider an expansion chassis to house the HD cards. You can then also expand your system beyond HD3.
As for the satellite option, it costs (in the UK at least) around 4 times more. So I guess it'd be roughly $1200 US.
Old 06-09-2009, 04:07 AM
M-ManLA's Avatar
That is True. I can get that then put everything in one system.
www.M-ManLA.com
Old 06-09-2009, 04:48 AM
PeterB PeterB is offline
1. Canopus ADC-110
Canopus is quick and easy so long as you use the Apple DV codec. Best way to convert? Buy the upgrade to Quicktime pro.
Its sync is OK, but you will need to calibrate the video offset in Protools to make sure audio and video are tight together.
Any other option is a lot more money I think....
Peter
Old 06-09-2009, 06:05 AM
JMDNYC JMDNYC is offline
My solution is to have both a Canopus with S-Video connection and a Video Satellite LE with a DVI to HDMI connection. They compliment each other in sometimes surprising ways.
For example, sometimes the VSLE looks really blocky and I have to zoom in on the video monitor. In those cases the Canopus looks noticeably better. h.264 looks really good on the VSLE, while higher defs can look choppy.
In my current film, all the Quicktimes are DVCPRO PAL, and my Canopus can't output PAL. Most editors are working off small computer monitors, but I'm using the Video Satellite on my 40" Sony Bravia.
On complex sessions I like having the VSLE to take the load off the main computer. VSLE lets you watch the picture during a bounce, but you need picture in your main session if you plan to bounce to Quicktime.
Old 06-09-2009, 08:01 AM
drenkrom drenkrom is offline
We also work mainly on commercials and the Canopus does the job very well. Working with DV can be a pain on longer material, but on the short stuff it does the job. The outputs are routed to VDA's for distribution to the TV's in the control rooms and booths. Everything also goes to the machine room video patch, where we can route it to any studio or VTR/editing station. A pretty stable setup (the Canopus may need to be rebooted once a month or so to correct a connection loss) and cheap enough that we can have a few spares in case one of the interfaces goes belly-up. I've had one die out of 12 in active use over 4 years. That's pretty stable.
Old 06-09-2009, 04:03 PM
jmdigi jmdigi is offline
The workstation that we are using are the Mac Pros (Second Gen, Pre Nehalem). This system will need to hook up to two video monitors..
Why look further? Your MacPro is already capable of outputting to two displays. I guess it depends on where you get your picture; I'm running transcoded Avid 1080p picture (transcoded to DVCproHD 720p until Avid fixes the Quicktime Codec) on a 37" 1080p display (DVI to HDMI) as well as driving a 26" LCD for PT timeline display. I've got a second video card driving two additional LCDs for mix and digibase displays. It's worked flawlessly since PT6.4.2 on my first gen MacPro and PTHD2.(Currently holding at 7.4.2, though that works fine in PT8 as well).
John
Old 06-09-2009, 11:43 PM
scottgreiner scottgreiner is offline
if you're going to be working in HD (which most people will be in the near future) your choices are a bit narrowed down
Video solution for PT 7.4 and pci-x G5 Duranchula Pro Tools TDM Systems (Mac) 2 07-10-2008 10:24 PM
HD Video Solution jeremiahjobe Pro Tools TDM Systems (Win) 3 10-17-2007 04:30 AM
A new video solution filmixer Post - Surround - Video 2 10-17-2004 02:42 AM
Video solution? Przemek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-04-2003 08:24 PM
digital video solution on a second Mac John Zuker Pro Tools TDM Systems (Mac) 3 07-19-2002 11:48 AM
