Old 02-28-2017, 11:19 AM
amagras amagras is offline
Default Re: Page scrolling working intermittently on 12.7
Please keep voting
amagrasmusic.com
Old 02-28-2017, 12:32 PM
onosendai onosendai is offline
I am not trying to be annoying. Just curious what is it supposed to do instead? I tried changing edit window scroll to page and zooming and scrolling works. The screen can jump, depending on whether or not insertion follows playback is engaged.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
Old 02-28-2017, 01:53 PM
If you do vertical zoom and the cursor falls outside the view, page scrolling will get stuck and won't follow the cursor unless you stop and start playback, sometimes a couple of times.
amagrasmusic.com
Old 02-28-2017, 02:10 PM
But isn't that because zooming is based on where your selection is and not the actual playhead position? So it would depend on the zoom level whether or not you will see a page break/jump? The way I experience it if the edit windows does not immediately follow the playhead is because it is outside of the zoomed view selection and it can be confusing whether the playhead is in front or after the given selection. The page breaking will latch back in if you zoom out including it in your timeline view.
Old 02-28-2017, 03:36 PM
YYR123's Avatar
YYR123 YYR123 is offline
Well maybe yes technically....but I want to see how this works on 12.5.1.
I bet it behaves like Amagras wants it to......which is the problem. If there was historic behavior that was changed, then this is what he is missing.
I will report back later.....traffic is crazy right now....don't go out unless you have too...
Daniel
Old 02-28-2017, 03:59 PM
@onosendai, I've been using PT since v7 and this is not working as it used to. Logic or not I need it the way it was, if I have to learn a DAW again it will be Digital Performer.
amagrasmusic.com
Old 02-28-2017, 10:25 PM
YYR123's Avatar
12.5.1
With insertion follows playback engaged (N key) button lit on screen
The page scrolling continues after restart.
With IFPB off (button not lit on screen) the page scrolling will not re-sync, if I can say it like that.
Daniel
Old 03-01-2017, 10:53 AM
Okay doke :) I have never used page scrolling consistently myself. However I'm always curious to learn and develop new workflows in PT's, which was the reason I asked.
If the function used to behave differently than presently then clearly something has been screwed up.
Old 03-01-2017, 11:49 AM
Super useful once you get used to it, please vote if you have time. Cheers
amagrasmusic.com
Old 03-01-2017, 12:50 PM
Upvoted.
Edit Window Scrolling / Page or No Scrolling" DAW Dogg macOS 2 02-15-2012 08:17 AM
When page scrolling stops Stig Eliassen Pro Tools TDM Systems (Mac) 0 11-18-2011 06:26 PM
MIDI edit page.... Edit Window Scrolling ... Page Norm Mix MIDI 1 07-06-2009 07:31 PM
WTF - page scrolling during playback? dmacintyre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-16-2009 11:48 AM
Page Scrolling bug in PT LE 7.1 Ron Streicher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-24-2006 12:41 AM
