Old 06-10-2007, 06:41 AM
mickdoo22 mickdoo22 is offline
Default Errors (-6086) and (-6093) H/W Buffer Mac Pro DIGI002
I am really in a major bind here. Here is my situation:
I have a BRAND NEW Mac Pro and DIGI002 system.
I just installed, following to the letter of the law....and this is what is happening when I try to play a session.
I open the DEMO session file, or any session I have on an external drive, and midway through playback i get stopped short with this error..."The operating system held off interrupts for too long. If this occurs frequently, try increasing the H/W buffer size in the playback engine panel. "(-6086) or (-6093).
This error message can occur at any point during playback, and happens EVERY time. I have gone into the Playback Engine panel and tried every conceivable combination of H/W buffer size, number of processors, CPU usage limit, and DAE Playback buffers, to no avail.
I am running NO PLUG-INS, and sessions with as few as 10 tracks. This system shouldn't even break a sweat with this. I am a fairly new Pro Tools convert, however I had a seasoned Pro Tools engineer here for 5 hours yesterday trying to figure it out and he is stumped as well. We searched the answer bases DUC for clues, and although we find plenty on this problem, no one seems to be dead in the water over this, and I see no difinitive solutions. In my case here, i can't run my system at all!
I am running a new Mac Pro 2x2GHZ Dual Core with 2gig RAM, (2) 500gig drives, one 250gig drive.
My system software is OS x 10.4.9.
My Digi setup is NEW DIGI002, Pro Tools LE 7.1.1.
I have downloaded the 7.3 update hoping that would be the answer and it wasn't.
I also saw where it recommended I install the OSx 10.4.9 Combi update. I downloaded this, and tried to install it, but I get an error message: "You cannot install Mac OS X combined (Intel) on this volume. This volume does not meet the requirements for this update".
I also tried downloading and running the "pre bind script". This did nothing.
I am dead in the water here.....its like having a Farari in the driveway that won't start. Any help anyone could provide would be much appreciated! Thanks in advance!
Old 06-10-2007, 09:01 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Errors (-6086) and (-6093) H/W Buffer Mac Pro DIGI002
Go through the troubleshooting tips at the top of this DUC.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-11-2007, 05:59 AM
Ok....so i ran through the troubleshooting tips at the top of this forum.....I followed step by step and I reboot, open a session file......and I am STILL having the same issues! I see on these forums that many people are running in to this problem, but I havent seen a solution. Can anyone help me with this???
Old 06-11-2007, 09:29 AM
DigiTechSupt's Avatar
Have you tried connecting the 002 to either port on the Mac Pro? It seems to prefer one or the other (some machines it's the rear port, some it's the front...).
What types of hard drives are you using?
Are you absolutely sure all INSTALLED plug-ins are the Intel Mac versions - having incompatible plug-ins installed, even if they're not being used in the session, can cause all kinds of problems.
Avid Audio Tech Support
Support FAQ
Old 06-11-2007, 11:11 AM
STAR NINE STAR NINE is offline
Quote
( I am a fairy........... new Pro Tools convert)
God-Mother, or Tooth?
I'm Sorry,
I Couldn't resist, That was Just, tooo Funny!!!.
Turn on you Spell Checker.
good luck with your Problem.
God Bless !!!!
Old 06-11-2007, 11:51 AM
As for plug-ins installed.....I ONLY have the ones that shipped with my DIGI 002 FACTORY Bundle. The unit shipped with Pro Tools LE 7.1.1, so i would assume they are Intel-Mac ready? If not, how can I tell?
My drives are Serial ATA, 7200rpm, 500 and 250 GIG drives. They should be ok.....?
I havent tried switching ports......I will try that this afternoon.
Old 06-11-2007, 12:49 PM
debolish debolish is offline
I'm getting the same errors as well - even with a single audio track, a 1024 buffer and zero plug-ins in my session.
I will try the front port this evening and report results.
Best,
JD
MacBook Pro M1 Max • 64 GB RAM • macOS Monterey 12.2 • PT 2021.12
Old 06-12-2007, 05:58 AM
session48 session48 is offline
Hey,
I've been having the same problem for sometime now and
I'm running a G5 2.5 Mac OS 10.4.8 with PT's version 7.1cs10.
I've also tried all the steps on the troubleshooting ,,switched
the ports ,updated and then some.I'm constantly getting the Error -6086.
I never had this problem with PT Version 6.9,until I went to 7.0 then
7.1 So hear I seat with the same problem.
It's extremely frustrating to no theres no Fix!
Hope you get it solved! Keep me posted
Take Care
Old 06-12-2007, 07:21 AM
Ok.....I SEEM to be running stable now! Before these steps, I couldnt get through a single playback without the errors killing me. However....one of....if not a combination of the following worked for me SO FAR. Yesterday I did these steps in this exact order....:
1. Verified all energy saver, spotlight settings were set as recommended by DIGI.
2. Downloaded the latest PACE drivers.
3. Deleted my Pro Tools preferences, emptied trash, and restarted.
4. Reapired my disk permissions.
5. Deleted the Digidesign database folder, emptied the trash, and restarted.
6. Plugged my DIGI 002 into the BACK port on my Mac Pro. (it had been in the front port.)
Since, I have had no issues...though it has only been a day. I haven't stressed the system yet, however everthing seems to be running fine. I will report more as I get a better feel.
For the record, I am running PT 7.1.1, OS X 10.4.9 on a Mac Pro.
Note: I have been reading through the DUC on this issues for the last several days solid. It seems to me that this is a complex, ongoing issue, that has MANY possible fixes. I hope DIGI is working to correct this, because it is obvioulsy VERY widespread. In the meantime, hopefully as people find what works for them , they continue to post the feedback to help other users, because this issue is a real bugger.
I hope this feedback helps others.....and I will post more as I find out more.
Old 08-01-2007, 09:03 PM
Jon Pruitt Jon Pruitt is offline
I was seeing a lot of errors on my 2.66 mac pro with PT 7.3 on OS 10.4.9 when I had 3 gigs of ram. Since then I added another 2 gigs of ram and now I see far fewer error messages.
6093 and 6086 errors lapas macOS 0 09-28-2012 05:57 PM
-6086 and -6093 errors nplmdthfan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-16-2009 05:24 PM
errors -6086 & -6093 on PT7.1cs10?? 16volt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-16-2007 09:37 PM
Any new BUFFER -6086/6093 tricks????? The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-11-2006 08:37 AM
H/W buffer size (-6086) (-6093) dalpal Pro Tools TDM Systems (Mac) 5 02-12-2005 08:27 AM
