Old 01-12-2020, 06:53 PM
Default Control/DADman flakiness
I am on EuControl 19.12.1.23, Avid Control 19.12.1.3 and DADman 5.3.4.5. I find that EuControl loses its connection to DADman – the Assign tab will re-assign Monitor and Control Room to Pro Tools, and unchecking/rechecking does nothing (it will not lock to anything).
Restarting DADman does not help, nor does disabling and reenabling EuCon in DADman.
https://lukehoward.com/
Old 01-12-2020, 09:29 PM
BScout BScout is offline
Default Re: Control/DADman flakiness
Do a complete uninstall of Eucontrol (including user preferences)
Then reinstall.
What OS are you on?
Also try toggling Eucon off/on on DADman.
I had similar problems until it was sorted and then its been rock solid.
Old 10-09-2021, 05:05 PM
Scanners Scanners is offline
Hi Luke are you still getting the problem or did u fix it? Ive just installed the setup here in Melbourne and its doing same flaky thing where I lose Dadman control in dock and can't adjust monitors levels or settings? cheers scanners
www.stevescanlon.com
Old 10-09-2021, 05:09 PM
It's definitely better, once it's working it stays working, and I don't think about it. But it is sensitive to startup order. If you quit EuCon whilst Pro Tools and DADman are running, and restart it, then I find you need to bring the apps to focus and then "re-lock" them to EuCon.
DADman does often need to be force-quit though, which is annoying.
Old 10-09-2021, 05:17 PM
thanks Luke restarted Dadman the Eucon, came back. Ill keep my eye on this, Mon fader went to full level as a default, damn. thanks again
Old 10-09-2021, 05:19 PM
If you want a "start safe" option, then save your DADman preset (I can't remember if this is stored in the main routing one or the monitor control one) with the monitors muted or dimmed, and disable save on exit. (I have my default one with ref set but the monitors muted.)
Conversely if you want to just pick up where you left off, then you can enable save on exit.
Old 10-09-2021, 05:22 PM
I will look for this good hint, nailed it!
DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL Mr Base Avid S1, S3, Dock and Control App 2 08-03-2019 11:06 PM
Elastic Audio flakiness (timing, nulls, etc.) yeloocevad Pro Tools TDM Systems (Mac) 13 12-02-2010 09:42 PM
Creative Prodikeys, midi flakiness, some days it works others not at all. Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-29-2009 11:33 AM
MTC chase flakiness Tim R. Pro Tools TDM Systems (Mac) 3 10-18-2005 09:54 AM
Import session data flakiness Tim R. Pro Tools TDM Systems (Mac) 0 12-11-2003 06:18 PM
