Old 06-10-2011, 05:11 AM
rofa rofa is offline
Default Focusrite LS56, MixControl freezes
I have a slight annoyance with Liquid Saffire 56 and it's MixControl program, when working on a fairly large project with lots of tracks (on a macbook, the CPU load is fairly close to the limit all the time), turning the monitor volume knob leads to a lag of a few seconds before the volume changes.
The level meters don't work at all in MixControl after I've started work on the session and even the menus take their time to react, even after I shut down Pro Tools again...
I can still work, but it's an annoyance trying to adjust the monitor levels...
Just recently updated to MixControl 2.2, no change. Seem familiar to anyone?
Old 06-17-2011, 02:01 AM
JoeFocusrite JoeFocusrite is offline
Focusrite
Default Re: Focusrite LS56, MixControl freezes
Hi there,
It sounds like you're using a firewire hard drive on the same bus as the Saffire that is using firewire 800. Is this the case?
We do not recommend using a firewire 800 hard drive as outlined in the following answerbase article:
http://www.focusrite.com/answerbase/...le.php?id=1141
Are you able to connect your hard drive using firewire 400 instead?
Joe
Focusrite Tech Support
Old 06-17-2011, 03:54 AM
It's a lacie d2 quadra, connectet Macbook <-FW400-> LS56 <-FW400-> lacie, both cables with FW400 connectors at each end. The macbook only has one FW400 connector, as does the lacie. The lacie has two FW800 connectors though.
Old 06-23-2011, 06:38 AM
bump
Old 06-24-2011, 02:23 AM
Focusrite
Hi there,
It's probably best to go into more troubleshooting by contacting us using the contact form on our answerbase located here:
http://www.focusrite.com/answerbase/en/contact.php
We cannot guarantee quick response times on here.
Joe
Old 09-19-2011, 11:04 AM
versechorusjvh versechorusjvh is offline
I'm having the same issue. Let me know if you've made any progress rofa. I'm trying the MixControl 2.4b tonight to see if that helps, so far none of the updates have changed anything. I think it should at least work as well as the 003 I was 'upgrading' from used to work!
Old 09-19-2011, 12:23 PM
recordingrevolution recordingrevolution is offline
I had that issue a few times with older versions of MixControl, but the new version 2.4 works great with Pro Tools 9.0.5. No problems yet.
Graham
Graham Cochrane
TheRecordingRevolution.com
"Make better music in your home studio with weekly tips, tutorials, and videos."
Old 04-01-2014, 01:36 PM
lukejazz lukejazz is offline
I know that this is from years ago, but after struggling with this issue for years and trying every possible solution, I finally solved the problem by recording straight onto my iMac Hard Drive. Obviously there's some issue getting the information to and from the hard drive (yes, a Glyph GT050) on a firewire 400 connection. Mix Control never crashes now and I have successful sessions. I still store all my sessions on the glyph but transfer to the iMac HD when I want to work. I've spoken to many people who haven't had this problem, but it has been a huge pain and time consuming for me.
Old 05-05-2014, 02:07 PM
Okay - just in case anyone ever checks this thread. I did finally get to the bottom of this. I recently had to replace my 2008 iMac with a new one (2014) and no more problems with MixControl. Must have been some problem with the iMac's firewire chipset all along.
Best wishes to all,
Luke
Distortion between Focusrite MixControl and PT9 pearldrum944 Third Party Interfaces 11 03-05-2014 01:57 PM
Focusrite LS56 with BLA Mod & Burl B1 JONK Buy & Sell 1 01-27-2014 08:39 AM
Focusrite LS56 Carpedrum macOS 3 04-01-2011 02:02 AM
Rosetta 200 vs. Focusrite LS56 vs. MR816 dccarson Pro Tools 9 1 12-17-2010 04:17 PM
Focusrite RTAS MixControl DannyG Pro Tools 9 1 11-23-2010 03:24 PM
