Old 11-03-2010, 01:46 PM
danatave danatave is offline
Default Control|24 mic inputs
I've got a Control|24 and an 002R connected via the DB25 cable. All line level inputs on the back of the Control|24 work fine. However when I try to use the mic (XLR) inputs, I get no audio. It allows me to change the source from mic to line to -10, but stays connected signal wise to the TRS input and has no effect on the level of the input when going from line to -10. I'm guessing that I'm missing a setting somewhere. Any suggestions?
Old 11-04-2010, 10:30 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default Re: Control|24 mic inputs
Haven't used one in a while, but does the XLR in require the phantom be on? I am pretty sure this is the case. Are the XLR connections you're using supplying phantom power?
I don't recall if I had used dynamics on them or not...
Throw a LDC or other phantom mic on a XLR on 1 in bank 1-8, nothing else on the other XLR's, and power phantom to 1-8
See if you get it then. If so, they require phantom. I believe this was the case, though, I sold mine over a year ago.
Never really used the mic pre's anyway....
As far as the pad goes... again, that may only be for Mic in. ???
Been a while...
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 11-04-2010, 02:25 PM
I tried it with a cond. mic from a drum kit & got audio. This begs 2 questions:
Why not allow the use of dyn. mics on these inputs.
Why even have a switch, if they don't work at all in the off position.
Hmmm!
003 - Gain control (Inputs 5-8) Amok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-07-2011 09:09 AM
How to add more inputs with Control 24 vesanie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-06-2009 01:21 PM
Control 24 Bundle...only 8 inputs!?!?! Noize919 Pro Tools TDM Systems (Mac) 6 05-17-2008 01:38 PM
Control 24 monitoring and aux inputs audio101 General Discussion 1 01-25-2001 11:40 AM
Control 24 various inputs audio101 Pro Tools TDM Systems (Mac) 1 01-25-2001 11:37 AM
