Re: Tablets running Eucon app not connecting with S1
Maybe this helps:
Neither Dante DVS nor Eucon support virtual interfaces (like a tagged VLAN on your physical EN adapter). Both need to be on a physical interface. You can put tagged VLANs on there but DVS or EC will just ignore them. For this reason I am forced to run EC and Dante on the same network (and physical port) as my second EN needs to go elsewhere. It works fine but there are only about 4-5 Dante devices on this network and all our tablets and S1s. It runs quite smoothly.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 11-07-2022 at 05:50 AM. |
How is the DNS server running....On Windows, a separate box? If its on 192.168.1.5, has it installed a virtual network adapter in Windows?
Well that was the setup here as well, one network to rule them all haha! Currently dividing the whole network in separate VLANs as the office also used to be on the same one-big-network even including domotics. However, I never had any issues with either Eucon or Dante or anything else.
About the DNS server, it's a dedicated server to host that and a ton of other applications via Unraid as OS (Linux). I still can't troubleshoot the issue of the tablets not connection out of nowhere. |
Is this dedicated server on a separate Ethernet adapter or connected via the switch?
It's a dedicated DNS adapter which has a dedicated NIC connected to the network.
Funfact: i was redoing the network with adding different VLANs and they seemed to work for the full 10 minutes. Then they disconnected again which is still the case up till this date. I have no clue what to do now. |
#16
ID'ing tablets and Unique ID for tablets - where from? | Rich Breen | Avid S1, S3, Dock and Control App | 4 | 03-14-2022 04:31 PM |
S3 OLED screens not working when connecting with EuCon 2021.6 | Leoespejo | Avid S1, S3, Dock and Control App | 3 | 07-28-2021 01:45 AM |
S3 with 2 tablets running Avid Control | SplitTheDifferenceAudio | Avid S1, S3, Dock and Control App | 5 | 04-30-2020 11:47 AM |
Eucon 3 - Artist Control not connecting to PT | Trazan | Artist Series | 50 | 04-04-2016 03:14 AM |
Eucon Windows BUG: some windows r stuck in background when Eucon running. | TuckerMix | Artist Series | 12 | 07-08-2014 01:37 PM |
