Old 09-04-2008, 08:27 AM
Kenny Gioia Kenny Gioia is offline
Default Free Recall Notes Plugin!!!!!
http://www.smassey.com/plugin.html
It's at the bottom. I never realized it was there.
Steve Massey rules!!!!!
Old 09-04-2008, 08:32 AM
Fidelis Fidelis is offline
Default Re: Free Recall Notes Plugin!!!!!
He is THE MAN!!!
Massey for president!
Thanks again Steve. Now we just need a great TDM Spectrum Analyser!!!
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 48GB RAM, OSX 10.13.6, PT HDX, PT 2020.9.1, SSL 4040G+, tons of outboard
Mac Book Pro 2019 2.4Ghz i5, 16GB RAM, OSX 10.14.6, PT Vanilla 2020.9.1
Old 09-04-2008, 08:42 AM
Stig Eliassen's Avatar
Aaah - awesome! Thanks, Steve.
Thanks, Kenny...
Old 09-04-2008, 09:33 AM
crizdee's Avatar
crizdee crizdee is offline
And the talkback i was actually going to request for this plugin and he's done it!!
Producer, Engineer,
www.ukmastering.com
Old 09-04-2008, 10:28 AM
Now we just need to share Recall presets.
I just made the Daking EQ and the Distressor.
Old 09-04-2008, 03:49 PM
crizdee's Avatar
Originally Posted by crizdee View Post
Actually Steve, could you code one to do almost the opposite? go into mute when the transport is stopped?? always wanted this for my effects returns when recording with the talent, as its nice to have the effects on when running the session, but not when your talking between takes etc.
Rock-on MR M
Producer, Engineer,
www.ukmastering.com
Old 09-04-2008, 05:46 PM
Andre Knecht Andre Knecht is offline
It bears repeating… one of the best aspects of using ProTools is its modular approach in building mixer components. ProTools is the audio equivalent of playing with Lego™. For example, I've been using “auto-muting” TB setups for ever (in both directions). Easy…
Auto-muting of TB Track during Playback
1 - Name a (mono) bus “*PB Key”
“PB” being PlayBack. I use an asterisk to distinguish—and identify at a glance—software paths from hardware ones.
2 - Create a “PB KEY” track (mono)
Put any continuos signal on this track—a low-mid frequency test tone will do nicely. To be frugal with disc space, print a few seconds of the test tone oscillator and repeat the region to cover the entire length of the session.
3 - Route the output of the “PB KEY” track to the “*PB Key” bus.
Use the track’s output, not a send. It keeps this key signal out of your monitoring and printing paths, and is more efficient DSP-wise.
4a - Insert Compressor With Key (sidechain) Input on your “TB Mic” track
Any compressor will do and its sound quality really doesn’t matter at all. What does matter is the the chosen processor be equipped with a “sidechain (Key) input.
4b - Select “*PB Key” bus as the (sidechain) Input on Compressor
In addition to selecting a “Key Source” some plugins require that the key/sidechain function be turned on, or switched from “Input,” or “internal,” etc. Know thy tools.
4c - Adjust Compressor Parameters
This is one of those rare occasions where the sledgehammer approach is preferred. The idea is for the compressor to clamp down as hard, fast and deeply as possible whenever the “PB KEY” signal appears at the sidechain input (which is only true when the transport is running). Like this:
Compression ratio: Maximum
Threshold: Adjust to be approximately 6dBs below the level of your steady key signal.
Range (where applicable): Maximum amount of gain reduction allowed by plugin.
Attack: Fastest setting possible
Release: Slow this down a bit (adjust to individual situations), just to create a smooth “fade in” of the TB mic(s), whenever the transport has stopped. This is especially welcomed by those in a session who are wearing headphones.
NOTE: Some compressors don’t offer enough gain reduction to completely mute a signal. No problem. Once all the steps listed above are completed, it becomes a simple matter of duplicating the compressor insert and its parameters until the required gain reduction is achieved. Option-dragging a plug-in is the fastest way to do this.
Auto-muting of Reverb Returns At Playback Stop
Repeat steps 1–3, as above.
4a - Insert Gate/Expander With Key/Sidechain Input on your “REV Return” AUX track(s)
4b - Select “*PB Key” bus as the key/sidechain Input on Gate/Exp
4c - Adjust Gate/Exp Parameters
The comments I added to steps 4a, 4b, and 4c in the first example, are valid here also, albeit adapted.
NOTE:
Be sure to eliminate (or make inactive) these gates/expanders prior to mixing. Even though your reverb signals will make it through as intended, their presence at this point is undesireable because…
a) you’re bound to unnecessarily color your delicate reverb signals, and…
b) they’re a waste of DSP.
The possibilities are nearly endless.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 09-04-2008, 06:56 PM
Howardk Howardk is offline
Great! Recall Notes is a must have. . . I can never find paper.
Question - I created a Popup list using the format popup: item1; item2; item3; and it works, but once created I can not see how to modify the popup list in the case one makes a mistake creating the Recall sheet template. Anyone know?
Old 09-05-2008, 06:30 AM
I would love to know as well.
Old 09-05-2008, 08:00 AM
crizdee's Avatar
NOTE:
IHTH.
ALL that faffing around and DSP usage
Lets just ask Steven Massey to make a plugin
Producer, Engineer,
www.ukmastering.com
Snapshot/plugin recall issue Realdon VENUE Live Sound Systems 5 05-01-2012 01:27 PM
Structure FREE shortens long notes aus scott Virtual Instruments 6 07-09-2009 07:07 PM
Structure free - Notes not sustaining anymore Murt Virtual Instruments 4 05-12-2009 03:30 AM
Power Harness Recall of the Recall ! ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 09:06 AM
PlugIn-recall of diff. setups-while runnig-Altiver Ploch Klaus Post - Surround - Video 3 12-29-2003 04:33 AM
