Old 07-16-2018, 09:45 AM
laurlaurlaur laurlaurlaur is offline
Default Akai Mpk Mini not connecting in Pro Tools
I've made sure to go step by for setting up both software. When I plug my mpk in, the light comes on and it works in other programs. It seems as if it is just not fully connecting to pro tools. The virtual instruments play with no isuue whemn I
I'm currently using Pro Tools 2018.4. I have a lenovo ideapad y700-15ISK. I have wiindows 10, 64 bit os. I'm using the audio interface that came with the computer. (microphone array, realtek high definition audio)
I need help
Thank you
Old 07-16-2018, 11:30 AM
Default Re: Akai Mpk Mini not connecting in Pro Tools
Did you set it up in the Midi studio menu?(you need to)
Old 01-17-2022, 11:30 AM
Sarge420 Sarge420 is offline
Hi all,
I'm having what appears to be the same issue... I've hooked up an Akai MPK Mini MK3 to my Pro Tools 11, I've set everything up in Midi Studio by the books, and I'm still not getting any signal through my instrument track when I play the controller .
Note: I've noticed that every time I try to set up the controller in Midi Studio it keeps resetting the input to "none" when I leave the window, this is probably at the heart of the issue, but I still don't know how to remedy this...
Thank yous in advance
Old 01-17-2022, 11:45 AM
junkgear's Avatar
junkgear junkgear is offline
Is the MPK connected to the computer before you start Pro Tools?
Is it selected in MIDI input devices?
Click the Setup menu, go to MIDI, then click MIDI Input Devices.
Ensure it is checked.
Do you have the instrument track record enabled?
Will
System Details
Old 01-18-2022, 05:22 AM
Yes to all of the above...I eventried to repair my PT installation...which ended up causing me a whole world of trouble after (I won't go into it here). Long story short, I've gone and reinstalled PT and I'll let yous know if it's changed anything.
Old 01-18-2022, 05:45 AM
Update: seems the problem is worse than I thought...every time I try to install PT it bricks my computer and I have to roll back to before the installation...guess it might be time to upgrade to 12
Old 01-18-2022, 06:26 AM
junkgear's Avatar
I'm not sure what you mean by bricking your computer, but if you are having issues re-installing Pro Tools, please start a new thread as this one will not get many views since its topic is about the MPK.
Will
System Details
Old 01-19-2022, 06:37 AM
In this particular case, bricking means that after I reinstalled PT and restarted the computer (as the installer instructed me to do), the computer was unable to boot anymore. I ended up rolling back to before the installation and getting the latest edition, after which I was able to connect the MPK Mini and control midi with it.
Mbox Mini (3rd gen) not connecting in High Sierra on old Mac Mini or new iMac Hoevelmann FireWire & USB Audio Interfaces (Mac) 0 04-26-2018 09:49 AM
connecting akai mpk mini with protools akaimpkmini Pro Tools 12 5 10-23-2016 09:47 AM
AKAI MPK mini in Pro Tools 8 M-Powered BreakingLegend Windows 0 07-13-2015 06:24 PM
Syncing the AKAI MINI MPK with Pro Tools 9 theorowe MIDI 1 10-25-2012 09:51 AM
any guides or primer on using Akai MPK mini with Pro Tools luism macOS 2 03-31-2012 05:51 PM
