Old 07-20-2015, 06:09 AM
Drew Mazurek's Avatar
Default Re: Bought a fresh Macbook running Yosemite, can't use PT10
Originally Posted by JFreak View Post
That is true; however, if one is using a TDM/RTAS plugin that has no AAX version it might become a problem ;(
Of course, but unless these mixes were started over ~2 years ago, that seems unlikely. OP never says, so I took an educated guess!
www.drewmazurek.com
Old 07-20-2015, 08:46 AM
JFreak's Avatar
JFreak JFreak is offline
Comme ci comme ca. If there are zero TDM/RTAS, then PT12 will be the best way forward
Janne
Old 07-20-2015, 04:56 PM
thierryhenry thierryhenry is offline
Thanks for the input guys I will be making PT12 work for me. Yes there were a couple projects started almost 2 years ago but hey.
By the way I just found this thread that says they're working on getting PT10 compatible with Yosemite:
http://www.everymac.com/systems/appl...lay-specs.html
Old 07-20-2015, 09:01 PM
Thanks for the responses so far. One suggestion i've seen on another thread on this forum is to manually change my mac OS system version, install PT10, and then quickly change the number of my OS system version back to 10.10.4.
Does anybody have more of an educated opinion on this?? Sounds pretty dangerous but if it'll work then I don't mind doing it.
Thanks in advance
ps. this was the link that was posted in the thread:
http://justindaigle.com/blog/2010/02...ystem-version/
Old 07-20-2015, 10:15 PM
JFreak's Avatar
It's just a text file that an installer checks prior to starting the procedure. Change it, start the installer, then change it back.
But bear in mind that even though you might manage to install PT10 on Yosemite, the experience might not be what you expect. For example, the plugin menus will be blank and things like that. Known issues Avid isn't going to address because PT10 is not intended to be compatible with Yosemite or Mavericks.
Janne
  #16
Old 07-21-2015, 04:03 AM
Craig F Craig F is offline
and I got this bridge in Brooklyn for sale
Thank you,
Craig
  #17
Old 07-22-2015, 04:07 AM
There's nothing there that mentions PT. Maybe you put in the wrong link?
Jack
QAPLA!
  #18
Old 07-22-2015, 11:53 AM
JFreak's Avatar
Yep, he said so already. The correct link is in the following post
Janne
  #19
Old 07-22-2015, 01:43 PM
Thanks but even in the correct link I can find nothing that says Avid is working on making PT10 Yosemite compatible.
Jack
QAPLA!
  #20
Old 08-03-2015, 06:12 PM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
This page says current MBP's come pre-installed with 10.10.3 which means you shouldn't try installing anything but Yosemite on it.
This page says that you need PT11.3 or later for Yosemite.
OP said his options are 10/12, so therefore he needs to make PT12 work.
That's incorrect. He doesn't "need" to make 12 work, he can install Mavericks and use PT10 as I did, and as others have done.
OS X 10.10.3 Yosemite Running for anyone on PT 11.3.1 HD gives Pro Tools 11 5 04-28-2015 01:29 PM
Yosemite and PT10 Eric Lambert Pro Tools 10 27 01-24-2015 02:29 PM
Bought PT10, do I remove the PT10 demo? esperanto macOS 2 04-18-2012 12:01 PM
Which MacBook Pro processor is best for running PT10 LE? johnbarnesiii macOS 8 02-26-2012 11:48 AM
Anyone have luck running PT10 on a Macbook Air? GKinTN macOS 2 01-26-2012 12:18 PM
