Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 03-04-2017, 10:14 AM
slidincharlie slidincharlie is offline
Default Very long launch time + continuous crashes
Hello community.
Total noob here
PTF installed okay after solving the 'AAE error -6117' issue.
Procedure for system startup:
-connect audio interface Behringer UMC404HD
-turn the notebook on
-launch PTF.
1st issue:
is a3m15 s launch time normal?
2nd issue:
after the second or third key pressed in PTF for whatever reason (e.g., create a project then hit any part of the Arrange window), PTF crashes.
No other software open, no other device inserted except the UMC404HD.
I have followed all the optimization steps.
--Carlo
Lenovo Thinkpad W530 notebook
Windows 7 Pro 64 bit
RAM: 8 GB
___________
SiSoftware Sandra
ID
Host Name : carlo-lenovo
Workgroup : WORKGROUP
Computer
Model : Lenovo 24474KG ThinkPad W530
Serial Number : PK0BF3A
Chassis : Lenovo Notebook
Mainboard : Lenovo 24474KG
Serial Number : 1ZSF537P29X
BIOS : Lenovo G5ETA5WW (2.65 ) 03/04/2016
TPM - Trusted Platform Module : 1.02, STM
Total Memory : 7.66GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (4C 8T 2GHz/3.4GHz, 2GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC PGA988 (G2)
Chipset
Memory Controller : Lenovo Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit
Memory Module(s)
Memory Module : Samsung M471B5173BH0-CK0 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Lenovo LCD 1600x900 (1600x900, B156RW01 V1
, 15.3")
Video Adapter : NVIDIA Quadro K1000M (1CU 192SP SM5.0 850MHz, 256kB L2, 2GB 1.8GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
CUDA GP Processor : NVIDIA Quadro K1000M (192SP 1C 850MHz, 256kB L2, 2GB 1.8GHz 128-bit)
OpenCL GP Processor : NVIDIA Quadro K1000M (192SP 1C 850MHz, 16kB L2, 2GB 1.8GHz 128-bit)
Compute Shader Processor : NVIDIA Quadro K1000M (192SP 1C 850MHz, 256kB L2, 2GB 1.8GHz 128-bit)
OpenGL Processor : Quadro K1000M/PCIe/SSE2 (2GB)
Storage Devices
HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache) : 466GB (C:) (Q:)
HL-DT-ST DVDRAM GT80N (SATA150, DVD+-RW, CD-RW, 768kB Cache) : N/A (E:)
ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (D:)
ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (F:)
Logical Storage Devices
SYSTEM_DRV : 1GB (NTFS, 4kB) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache)
Windows7_OS (C:) : 447GB (NTFS, 4kB) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache)
Lenovo_Recovery (Q:) : 18GB (NTFS, 4kB) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache)
Optical Drive (E:) : N/A @ HL-DT-ST DVDRAM GT80N (SATA150, DVD+-RW, CD-RW, 768kB Cache)
Optical Drive (D:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache)
Optical Drive (F:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache)
Peripherals
LPC Hub Controller 1 : Lenovo Panther Point LPC Controller
Audio Device : Lenovo Panther Point High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : Lenovo GK107 HDMI Audio Controller
Audio Codec : nVidia GeForce 6800 LE [NV40.2]
Disk Controller : Lenovo Panther Point Mobile 6 port SATA AHCI Controller
USB Controller 1 : Lenovo Panther Point USB xHCI Host Controller
USB Controller 2 : Lenovo Panther Point USB Enhanced Host Controller #2
USB Controller 3 : Lenovo Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : HP LaserJet 500 color MFP M575 PCL 6 (600x600)
Printer : HP LaserJet 4200/4300 PCL6 (600x600, Colour)
Printer : Canon MG5600 series Printer (Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Network Services
Network Adapter : Intel(R) 82579LM Gigabit Network Connection (Ethernet)
Network Adapter : Dispositivo Bluetooth (Personal Area Network) (Ethernet)
Wireless Adapter : Intel(R) Centrino(R) Ultimate-N 6300 AGN (802.11n (HT), AES-CCMP, 144Mbps)
Power Management
Battery No 1 : LGC 45N1011 93.60Wh/8.38Ah
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Old 03-12-2017, 09:38 PM
BlackHelicopter BlackHelicopter is offline
Default Re: Very long launch time + continuous crashes
Don't worry you're not alone. This software sucks. Period.
You're better off not wasting your time and just using something else until AVID decides they want to back up their product.
Old 10-05-2018, 11:05 AM
fredmant fredmant is offline
Charlie, the fact that you're running Windows 7 with only 8 GB of memory could be a large part of your problem, but try running PT with the Behringer turned off. Don't worry about the error message you'll get as long as you don't try saving the session, you should be fine.
Fred
Workspace re-syncs all the time. Is this normal? audiofreak11 macOS 2 03-08-2013 01:00 PM
How much memory usage does your PT take up on normal launch ? hwill2008 Pro Tools 9 2 04-27-2011 07:11 PM
PT Crash - is this normal? black030 Pro Tools TDM Systems (Win) 1 05-05-2007 11:11 AM
continuous time code from USD or Sync I/O bricoleur Post - Surround - Video 1 09-03-2004 05:42 AM
nasty bug in 5.3.1 XP (normal Windows Key combo causes PT/OS to crash) Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-18-2003 06:20 PM
