New URS Channel Strip Pro!
YES Ladies and Gentlemen URS has released the Channel Strip Pro!
http://www.ursplugins.com/ursStripPro.html From the URS web page: URS Classic Console Strip Pro™ 30 Selectable Input Stage Algorithms 60 Selectable Channel Compressor/ Limiter starting points - Pre or Post EQ 5 Selectable EQ Algorithms for each Fully Sweepable Parametric band Channel Filters - Pre or Post Compressor or Sidechainable Powerful De-esser and other included special effects Interactive Signal Flow Display Section follows the signal path Super DSP efficient URS Classic Console Strip version included The URS Classic Console Strip Pro is our ultimate multi console in the box channel strip solution. You the engineer create your dream console choosing your favorite algorithms from the Input Stage, Compressor and EQ selections. The URS Classic Console Strip Pro is a revolutionary new way of combining classic sounds into one unified channel strip. This modern concept allows the engineer to create hundreds of custom console starting points from the almost never ending palette of input stages, compressor/limiter and EQ choices all with near zero latency and full 48 bit Double Precision Processing. Listen to what we believe is the most versatile and best sounding classic console strip that was never made before! From the moment you put the URS Classic Console Strip Pro input stages in circuit you will hear the difference! Selectable Input Stage Algorithms digitally recreate the sound and characteristics of classic input stages to add warmth. The Input Stage Intensity control adjusts the Input Stage affect from 0-200%. Thirty (30) input stages are presently included: Three Class A American input transformers Class A British input transformer Class A German input transformer Two Class A tube input stages 15ips 2" tape electronics/head bump 30ips 2" tape electronics/head bump 30ips 1/2" tape electronics/head bump Fifteen input transformer & tape combos Five Console Input/Summing Buss stages A Digital transparent Input stage is also provided which adds no colorization, harmonics and/or saturation. In your face Interactive Signal Flow Button Display No confusion here! The signal flow button display section shows the signal path of Compressor, Filters and EQ sections. The labeling of the buttons updates automatically as per the status of the Compressor and Filters section Pre/Post switches. In addition, each signal flow button acts as a bypass for the section it represents. Independent Compressor, Filters and EQ sections The Compressor, Filters and EQ sections are totally independent of each other featuring separate In/Out switching via the Signal Flow Button Display. The Compressor section is selectable between Pre/Post the EQ section. The Filters section is selectable Pre/Post /Sidechain the Compressor section. Compressor/Limiter section features a custom designed versatile channel compressor that can match the sound and characteristics of Diode Bridge, VCA, Fet, Opto, Tube and Tape compression. The compressor starting points are based on the most prized compressors limiters in recording studio history, The URS Classic Console Strip Pro features 14 classic console compressor/limiter models and 46 outboard compressor/limiter models. The compressor starting points simultaneously change the input stage algorithms to suit the compressor preset. The Compressor features fully adjustable Threshold, Ratio, Knee, Attack, Release and Gain Makeup. Adjustable from soft to aggressive! Presently 60 Compressor presets are included: Two 1967 Americian Channel Comp presets Five 1970 British Channel Comp presets Two 1970 British Channel Limiter presets Five 1980 British VCA Channel Comp presets Five Fet presets Four Opto presets Room Mic preset Four Stress presets Five Tape Compression presets Twelve Tube Compression presets Seven American VCA presets Two Very-New presets Three Class A Buss Comp presets Three URS Classic Console Strip presets Filters/Side chain section can be assigned either Pre/Post Compressor or as the Compressor's Side chain. Using the Side chain feature can fine tune how narrow or "Broad Band" the Compressor will affect the program material. Both Filters completely overlap to dial in problem frequencies. The Listen Key is after the Internal/ External Side Chain Filters section. The Listen Key allows you to monitor the signal being sent to the Gain Reduction detection circuit. Presently 6 Side chain presets are included Six Classic VCA De-esser presets Two Drum VCA Ducker presets British Talkback Mic Preset Telephone preset Brand New EQ Algorithims The URS Strip Pro features all new EQ Algorithim technolgy. The digitally recreated Analog EQs represent the cutting edge in EQ modeling. EQ section digitally recreates the sound of four different analog consoles plus a Vintage Tube program EQ. All bands features fully sweepable frequency and "Q" bandwidth selection, The Mid range bands overlap over four octaves of frequency selection. The LF and HF EQ Bands are selectable Peak or Shelving. Each EQ band presently selects from either: 1951 Program EQ - Tube 1967 Console EQ - American 4 Band 1970 Console EQ - British 3 band Class A 1972 Console EQ - British 4 band Class A/B 1980 Console EQ - British 4 Band Room to grow The URS Classic Console Strip Pro’s unified GUI allows room to add more Input Stages, Compressor and EQ algorithms as they are developed. High Res 48 bit "Double Precision" processing The URS Strip TDM version features Hi Resolution 48-bit TDM and URS Classic Console Strip Native features 64-bit "Double Precision" processing for increased clarity and headroom with unparalleled gain reduction. Hi Resolution "Double Precision" processing helps to avoid internal clipping in the Digital Domain. Two Plug-ins included The URS Strip Pro includes the super DSP efficient URS Strip version. We call the URS Classic Console Strip the "Easy Eight". The URS Classic Console Strip's eight knobs map perfectly to the Command 8, Digi002, ProjectMix I/O, ProControl, HUI and other popular controllers allowing for quick adjustments on individual tracks. The eight knobs map to Page table 1 and all other functions map to Page table 2. URS Strip Pro URS Strip Features Pro Tools HD and LE 7.x.x and Tiger OSX 10.4.10 PPC and Intel UB compatibility Pro Tools HD and LE 6.9.2 and Tiger OSX 10.3.9 PPC compatibility Pro Tools HD and LE 6.x.x - 6.9 and Panther OSX 10.2.1 PPC compatibility Pro Tools M-Powered LE version 7.x.x compatibility Available only for Macintosh TDM, RTAS and Audio Units at present Windows XP and VST support to be announced! Full Pro Tools TDM support for Pro Tools|HD Accel and Pro Tools|HD Full 192 kHz support for TDM, RTAS and AudioSuite versions Full D Command, ProControl, Control|24, Command|8, 003 and Digi 002 support Full ICON Console Control Surface support — including center section Dynamics panel Supports Mbox 2 Pro Mbox 2, Mbox Mini, 003, 003 Rack, Digi 002, Digi 002 Rack, Pro Tools|24 MIX, Pro Tools|HD and Pro Tools|HD Accel and M-Audio Interfaces. Strip Pro Specifications Variable input stage algorithms with Intesity adjust 0-200% Compressor Threshold Leve - Variable Variable Compressor Ratio 1.1:1, 1.2:1, 1.3:1, 1.4:1, 1.5:1,1.6:1, 1.7:1, 1.8:1. 1.9:1 2:1, 2.5:1, 3:1, 3.5:1, 4:1. 4.5:1, 5:1, 5.5:1, 6:1, 6.5:1, 7:1, 8:1, 9:1, 10:1, 20:1, 35:1, 50:1, 100:1 Variable Compressor Knee - from Hard to Soft Variable Compressor Attack Time 1ms - 50ms. Variable Compressor Release Time 100ms - 1500ms. Compressor Gain Make up Output Control Compressor section selectable Pre or Post EQ section Sweepable LF Sweep between 35hz and 500hz - Peak or Shelf Sweepable LMF Sweep between 200hz to 7.5k Sweepable HMF Sweep between 200hz to 7.5k Sweepable HF Sweep between 1.5k and 20k - Peak or Shelf All EQ Bands Cut/Boost -15db - +15db Variable Hi-pass Filter - EQ section or Side chain @ 12dB per Octave 20hz to 5K Variable Lo-pass Filter EQ section or Side chain @ 12dB per Octave 20Khz to 1k Signal Flow section In / Out Bypass switches for Compressor, Filters and EQ Master Line Input Trim offers -10 to +20 gain variable to .1db Master Line Output Trim offers -10 to +20 gain variable to .1db Gain Reduction Meter - selectable Limiter, Compressor or both Plasma Style Input and Output VU Meters Strip Pro Instances - 5 per HD Accel chip and 2 Instances per HD chip Strip Specifications Transformer input stage emulation Compressor Threshold Level Compressor Ratio 1.5:1, 2:1, 2.5:1, 3:1, 3.5:1, 4:1. 4.5:1, 5:1, 5.5:1, 6:1, 6.5:1, 7:1, 8:1, 9:1, 10:1, 20:1, 35:1, 50:1, 100:1 Compressor Gain Make up Output Control Selectable A, B and C Attack /Release presets Compressor section In / Out Bypass switch Compressor section selectable Pre or Post EQ section Selectable Bass - 55hz, 110hz and 220hz Shelving Sweepable Midrange between .2k to 7.5k Selectable Wide or Sharp Midrange "Q" bandwidth Selectable Treble - 4.5khz, 8.5khz and 16khz Shelving All EQ Bands Cut/Boost -12db - +12db EQ section In / Out Bypass switch Phase reverse switch Line input Trim offers -10 to +20 gain variable to .1db Gain Reduction Meter - selectable Limiter, Compressor or both Plasma Style Input and Output VU Meters George Ware |
Re: New URS Channel Strip Pro!
$1500.00 US for tdm !!!!!!!...................................Dream freakin on!!
Thats a joke,,,,,,, dog
PT 9 Control 24 003 Rack Mac Pro 2.66 Quad Adam A7 Waves Gold, VSeries Pultec Bundle URS, McDSP |
The Win XP version is up, I can even run the Channelstrip Pro on my old TDM Mix system....Thanks URS
George Ware |
$1,500 is insane!
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
I wear the pants. (My wife picks them out) |
Channel Strip | YYR123 | macOS | 1 | 03-02-2013 08:45 PM |
Anyone using URS Channel Strip Pro? | ondruspat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-31-2008 04:40 PM |
URS Channel Strip | George Ware | Pro Tools TDM Systems (Win) | 0 | 05-31-2006 06:36 PM |
Renaissance channel vs Channel Strip | frenchman | Tips & Tricks | 1 | 09-20-2003 05:18 AM |
DBX 376 Channel Strip | Yah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-07-2002 12:01 AM |
