XMON displays as off on D-command intermittently
I have an original D-command and XMON (the light blue one) For the last week or so my Xmon displays "off" on my D-command intermittently. The display cycles showing "Xmon on" and "xmon off" every few minutes and this seems to be happening more frequently every day. Obviously the monitor section audibly cuts out when the Xmon shows"off". I've seen some similar references to this in this forum but can't seem to find a resolution. I've tried reseating the cables and resetting the D-command several times, as the Avid website suggests...but no lasting improvement. Does anyone have any experience/idea what the next step would be???...Obviously having it serviced is a daunting option (without even considering the downtime). Was hoping there is something else I might try first. Thanks
Re: XMON displays as off on D-command intermittently
I had the same experience, and Avid suggested that I replaced the PSU. You can easily do that yourself. That fixed the problem, but it only lasted for 3 weeks. I think the old PSU had caused other components to start failing as well, but I can't prove it.
same thing happening here....bummer. Mine is only happening every few days as of now.
Thanks |
Might be a long shot. But, I had some similar problems with xmon not showing up. I cleaned the serial cable connectors and that solved all of my problems.
Thanks!, cleaned the contacts with alcohol .... and for the moment it seems to have done the trick. not very hopeful though going forward.
I am using a D Command Blue with the Xmon but in the monitoring section it appears as (XM OFF), I am using a standard db15 cable since the last page of the D Command guide shows the PinOut graph using the 15 pins. Some help? Thank you...
Firstly; have you tried holding down the mute button on the XMON during power up? It's a reset procedure.
96I/O, XMON, D-command connection | sjtae | Pro Tools TDM Systems (Win) | 12 | 04-23-2017 10:06 PM |
D-Command and Xmon for sale | EdmundEagan | Buy & Sell | 2 | 04-04-2014 11:33 AM |
Xmon not seen as ON by D-Control / D-Command | Ruthven | Pro Tools TDM Systems (Mac) | 1 | 05-10-2011 12:56 PM |
D Command, PT 9, XMON, 002 | puffin | ICON & C|24 | 2 | 12-20-2010 01:38 PM |
Monitoring Cue Mix Through D-Command/XMon? | SimonInAustralia | ICON & C|24 | 9 | 03-02-2009 06:06 PM |
