Old 05-28-2019, 08:32 AM
FunkzzaJ FunkzzaJ is offline
Default Should I uninstall 2018.10 before installing 2019.5 ?
Q1:
Avid doc "Pro tools installation" says uninstall before installing new version.
Are we to use Windows uninstall function for that, or does the pro tools installer uninstall previous version?
Q2:
Going from 2018.10 to 2019.5 and from 1803 to 1809.
Have stopped windows update and is still on 1803 (windows 10) since 2018.10 is "not qualified" for 1809. However, 2019.5 is declared "qualified" for 1809 by avid, and it seems to work fine with 1809 from reading here at DUC.
Which one to upgrade first, windows or pro tools - any thoughts?
/FZJ
Old 05-28-2019, 11:12 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Should I uninstall 2018.10 before installing 2019.5 ?
Personally I’d upgrade the OS first then install the latest PT.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 05-28-2019, 11:18 AM
Southsidemusic's Avatar
Hear hear
Had you been on Mac you could install right over the old version but as you have windows make the unistall correctly before installing the latest version of PT.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-28-2019, 11:37 AM
off the wall's Avatar
off the wall off the wall is offline
Originally Posted by Southsidemusic View Post
Hear hear
On a Mac, I have always just installed over the previous version and never had an issue.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 05-28-2019, 11:44 AM
Same with us. Mac users here and we have never had any problems either but OP is a Windows user so a complete uninstall is needed before a new version is installed.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 05-28-2019, 12:03 PM
Thank you all
Will uninstall before updating.
/Tomas
Old 05-28-2019, 11:11 PM
i'm fine here for now. 2019.5 seems to be working just fine here. Still on windows 10/1803
thx again
Old 05-29-2019, 02:48 AM
Thank you for letting us know you have got PT up and running
We are here should you need anything else.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 06-28-2019, 11:03 AM
nstelton nstelton is offline
I have PT 2018.12 on Windows 10.
So, just to make sure I understand--to install PT 2019 I need to first use Windows uninstall to uninstall 2018.12, yes?
My concern is possibly losing customizations like plugins, I/O maps, or other settings, or access to existing sessions. Do I need to do (or not do) anything to make sure I don't lose anything?
Also, will I need to re-register anything with Avid or iLok?
2019 iMac i9 + PT 2018 + Mojave rwbreck General Discussion 41 11-22-2019 01:13 PM
Updating 2018.2 to 2019.5 bektolio Pro Tools 2019 15 05-11-2019 02:40 AM
first installing newest OSX build or first installing 2019.05 ? pm mastering studio Pro Tools 2019 1 05-10-2019 05:14 AM
Compatibility between 2018 and 2019? beatlogik Pro Tools 2019 2 05-09-2019 01:51 PM
