Old 11-04-2018, 10:11 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default What now? "must be the same length for the Clip Slide command to complete during reco
I'm recording a podcast and while I record 4 channels, I like to move clips around on the timeline for the presenters to be able to comment on it.
Was no problem before, but with 1218.10 I get this:
Could not complete your request because the clips on Track "AUDIO" do not appear to match in file size, duration, or position for multichannel processing. These clips and their corresponding audio files must be the same length for the Clip Slide command to complete during record.
What on earth does this mean?
Even copied it to a fresh track (nope) and consolidated a clip) nope...
Reconfigured I/O setup to stereo instead of multichannel: no sir.
What to do?
EDIT: tried this in a fresh session: all fine. imported the problematic track: same problem. Very weird.
Arno Peeters
Tape TV Productions
Old 11-05-2018, 03:26 PM
john1192 john1192 is offline
Default Re: What now? "must be the same length for the Clip Slide command to complete during
Hi Arno, was the track that is problematic from an older session ???
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-03-2019, 06:39 AM
Sorry to answer so late: no, not from an older session.
Today it happened again: I Googled the error-message
Could not complete your request because the clips on Track "Audio 1" do not appear to match in file size, duration, or position for multichannel processing. These clips and their corresponding audio files must be the same length for the Trim Clip Gain command to complete during record.
and ended up at my own post
Repaired disk permissions and set drive to ignore ownership, but the error stays: during recording I cannot do anything to clips: fade, move, splice...
Saved a copy of the session, still the same problem.
Any ideas?
Arno Peeters
Tape TV Productions
Old 06-13-2019, 03:12 AM
Found my answer in an older post:
You've got mono tracks that have been recorded at separate times then moved to a stereo track.
Split stereo whichever tracks you're having trouble with to mono and you should be good :)
That indeed fixed it for me. Now the only thing is to make sure it never happens again. I use a simple dirty trick to prepare a session for a podcast; I import a bunch of items and drag them onto the playback track. Than I switch that track to Tick base and lower the session tempo, making all clips spaced (to be able to record commentary in between) and than switch back to Time-based. Somehow that messes things up, apparently.
Just posting this in case someone else is looking for the same error-message.
Arno Peeters
Tape TV Productions
command-/alt-plus/minus extends clip to wrong length Frank Kruse Post - Surround - Video 6 04-25-2013 06:48 AM
Could not complete the Open Session..command Assertion "KeyContextRegistry" line72 JLiRD808 Windows 4 12-25-2012 01:01 PM
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon macOS 1 02-29-2012 07:03 AM
Help with "Could not complete the exit command because Access Violation occurrred" keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-06-2010 06:24 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
