Old 02-09-2007, 06:50 PM
TomLewis TomLewis is offline
Default Colin Broad Sr4 syncronizer
Anybody out there using a Colin Broad Sr-4 synchronizer?
We have Pro Tools 7.2 on Windows. We are considering purchasing a new synchronizer. What I would like to do is have the synchronizer control Pro Tools via machine control deck emulation.
The reason for this is that we need to record our DME stems in Pro Tools at the same time we are laying back to tape. Our current work flow is to record mixes to Digibeta and DMEs to DA88 using TimeLine Microlynx. However we are moving into HD and have purchased Sony SRW5500 and Panasonic DVCproHD. The microlynx does not have machine templets for these new decks, thus our purchase consideration. And yes I know I can just use machine control. But only if I mix my stems to Pro Tools first and then do a layback pass. We generally don't have the time for the layback pass. We do "live layback" during the mix.
So, I know the SR-4 is one of the on;y qualified synchronizers to control Pro Tools. How do you set it up? And how well does it work?
Thanks in advance.
Tom Lewis
Old 02-09-2007, 09:48 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Colin Broad Sr4 syncronizer
Email Bill here:
http://www.timelinevista.net/
He's the only guy left who services them, ex-Timeline service man.
See if he can help you with new machine profiles, couldnt hurt!!!!
IMDB
Old 02-27-2008, 02:14 PM
dcaudio dcaudio is offline
Hey,
What is it about machine control that prevents an external "live layback" to a tape deck and printing stems internally to protools at the same time?
I print 8 tracks of DA88 and multiple stems in PT's at the same time: DA88 is master, PT's tracks put armed, PT's online, press record on the DA88 and sha-bam! And I do this without Machine Control (the DA88 is right next to the mix position).
I do occasionaly have lip sync issues, but I think that is the madness of Delay Compensation...
Old 02-27-2008, 04:00 PM
SBP SBP is offline
The dual transport mode on Icon (7.4cs2) lets you do this. (Well part of what you want ie one machine and pro tools tracks) At least I was able to do it this week on a project.
In Destructive record mode with a pre-roll setting.
1 -set point that you want to drop in on pro tools tracks.
2 -with ProTools transport active hit record.
3 -Once "in sync" hit machine transport once then hit record on machine transport.
you'll be recording to Protools and to machine.
-It would be nice if you could drop into both as one setting but this work around didn't seem too painful.
Cheers
Bruno
Old 02-28-2008, 12:58 PM
macaholic macaholic is offline
I second what dcaudio said.
You just have to enable "Transport Record Lock" in your Preferences>Operation in the "Record" section. Print stems and layback to tape at the same time.
JC Richardson C.A.S.
Magick Lantern
Atlanta
Old 02-28-2008, 01:18 PM
quadraphonics quadraphonics is offline
I have had issues trying to do the same thing you are mentioning. We have Digi's machine control software running on a Mac Pro 2x2.66 pt. 7.3.1cs6
Whenever we engage the track inside of protools that we want to record our audio to, it kicks the 5500 into PreRead mode.
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 06-14-2010, 08:03 AM
bdangler bdangler is offline
Man, I keep having this problem. With the older gray 5500 decks, when I record-enable tracks in PT to record the stems, it kicks the deck into pre-read. This doesn't happen on the newer black decks we have. Has anyone figured this out? I'm on 8.0.3 HD
Old 06-15-2010, 01:55 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
The SR 4 is a complex and clever beast but NOT intuitive. The same goes for Colin - unless you speak 9- pin!
Why not record your stems in PT at the same time as laying back mix to vt?
I do it all the time with destructive record and preroll - a few more button presses, but much easier than diving into the SR 4. When oh when will digi (oops Avid) let us drop in to ext mc and PT at the same time.
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 06-17-2010, 02:33 PM
jahtao jahtao is offline
Have never done this but would like to know how, care to explain which buttons to press and when? : ) Hugely appreciated! It's sure to come in very useful at some point.
(With my present understanding, I have to go the DA88 route if I want stems + a digi simultaneously)
Matt
Old 06-17-2010, 03:03 PM
shortcuts for switching between ext machine and protools (if you don't have an icon) is command + \ (I use these keys as I switch consoles a lot between Icons and ProControl)
not in my studio now, but from memory (gosh it's hard when you aren't actually doing it):
set up machine control
set your pre-roll to 75 frames for vt machine in the machine control page
cmd + 6 to select insert tracks on VT
select pro tools as transport
select destructive record
arm your stem tracks in PT
control +K to enable pre and post roll (set to 3 sec pre and 1 post)
put external vt on line (which I think is alt + spacebar)
hit the star key on the numeric keypad
enter your timecode for record start (10:00:00:00 for the pal types here)
hit 3 on numeric keypad (enables record - initiates sequence)
once pt is prerolling and locating vt , hit command + \ to select VT as transport (don't wory about PT - it will still auto record at 10:00:00:00)
drop vt into edit and voila - both vt and PT are in record
now you know why the pre roll times are in, to allow time to do the cmd + \ command to switch transports and drop vt into record
I final mix live to VT and layback stems into PT all the time at AETN uk - keeps you on your toes.....
sing alleluia and praise your kind friend mikerophonics - it's past my bed time!
cheers
BAFTA member
IPS member
HTML code is On
Satellite Link and the Colin Broad PD-1 Matt Reale Post - Surround - Video 3 03-15-2012 08:19 PM
PT8 and Colin Broad PD-1 TAFF Pro Tools TDM Systems (Mac) 0 06-29-2009 04:59 AM
Broad Pro Tools Questions thebmp General Discussion 6 02-09-2006 10:30 AM
Anyone using Colin Broad 9 pin converter with Pioneer DVD? Wolfgang Eller Post - Surround - Video 0 04-24-2003 12:33 AM
Bravo Colin (McDSP) iLok debugging for HD !!! Ray Fabi Pro Tools TDM Systems (Mac) 2 05-29-2002 06:45 PM
