Do you have probs w/ digi tech support utility?? I have a fix!
K everyone, got back to scripting a bit, been WAY busy, but decided in the midst of all this computer and os testing going on a couple things i am doing repeatedly that i want automated!! stayed up way to late last night....this morning i mean.....and some more later that morning and created this cool little app.
We all know the probs with the digidesign tech support utility........the valid installation warning, not working with multiple os's of different types, 64 bit os, newer versions of pro tools..and so on. I have streamlined this process and added a couple extras in with it Give it a go, includes a readme with all the details i could think of. Please read it first, very simple control, should be fool proof. I have tested on xp, vista and win 7 32 and 64 bit. and fyi, it is an exe file and might be mistaken for a virus, i am not spreading virus's __________________________________________________ __________________________________________________ _________________________ There are different versions of this application. This version is for pro tools version 8.01 and below on xp 32bit os only. TRASHER 8.01 and earlier Please follow the directions in the readme included in the download. __________________________________________________ __________________________________________________ _________________________ This version is for Pro Tools 8.04-9 (so far all cs updates) on Windows 7 for both 32 and 64 bit os. This version has a gui and some extra little goodies. TRASHER 2.0 Place in your documents folder, launch the app and the readme will be available with all needed info. __________________________________________________ __________________________________________________ _________________________ *********11-28-12********** Pro Tools 10-10.34 For W7 64 and 32 bit os only. Lots of extra backup and restore options from the previous build. Also now instead of deleting folders and replacing them, it will now merge the folders into each other to reduce the risk of possibly losing any files. Many other improvements. Complete list available in the gui. The new .exe will be labeled TRASHER 10 V5 TRASHER 10 Same as before: place inside your documents folder (NOT public documents folder) and a readme is availabe with all the needed info. __________________________________________________ __________________________________________________ _________________________ *******8-5-13******* Pro Tools 10.3.5+ build 5.7 TRASHER 10.5 Now includes an installer. Extract and run from desktop only. A Read Me is available from the GUI once its running. There is also a Read Me for the installer to answer any questions once its extracted. Please ask any questions or problems in this thread or the email address on the GUI. New build (5.7) with some code revisions and tweaks. all operations will function the same. New Icon Any users of PT 10.3.5 and up are highly encouraged to update to this build. If you have a previous build installed, Nothing needs changed except the .exe file (NOT the installer .exe) and the main Read Me.pdf Just Delete the previous .exe off of your desktop (and unpin from Taskbar or Start menu) delete the .exe out of your TRASHER data folder. Replace with the new one then drag to your desktop or just pin to your Taskbar or Start menu. IF this will be a new install or installing over TRASHER 10, run the Installer .exe and choose the appropriate selection. __________________________________________________ __________________________________________________ _________________________ ******8-5-13************ TRASHER for PT 11/10.3.6+ TRASHER 11 Extract onto and run the installer from the Desktop ONLY. Installs the same as 10.5 After running the installer .exe a menu will appear to allow a new install or install over TRASHER 10-10.5 IF you choose to install over 10-10.5, it will copy the contents of all the backed up TRASHER folders into the appropriate spot inside TRASHER 11 for PT 10.3.5+ content. This will work for both PT 11 and 10.3.5 and above, but specifically built for the dual install of both 11 and 10.3.6+ Slightly different design Many new features to address the changes off PT 11. Highly recommend going through the 11 Read Me before using. I would like to start a simple site to host and off better support and communication for users. Things are quite spread out and proving difficult to keep up. I would ask any donations toward this cause would be appreciated.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 Last edited by guitardom; 09-05-2015 at 09:57 AM. |
Re: do you have probs w/ digi tech suprt utility?? i got a fix!
Thanks.
my pleasure, please let me know how it works for you and what you think about it.
i in initially thought it would take me 20 min to do it, but after getting into the details of doing it properly and having it capable of working for different people on different systems was a whole new game!!!
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Hey Guitardom, can you send me the tech support utility you came up with, please? I'm running on Vista Business & wouldn't mind an easier way of optimizing my pc. Thanks.
Steve I got '2' word for ya-----Brilliant
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
(thanks for the compliment as well kb) i have an updated version of it, it is on this forum somewhere, but this version will work fine.
Oops.. my bad. Thanks guitardom! Some of you are a little too uptight on here though. Everyone's human.. sheeeez
Ur rite... We shouldn't be so Soon to Dot people
A new motto for the day.
Thanks, GD..! Will give it a go and let you know how it goes.. :)
Tech Support Utility Fail | audiogeekzine | Pro Tools M-Powered (Win) | 2 | 08-23-2010 07:20 PM |
Digi Tech utility launch message | Kirby B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-20-2009 02:12 AM |
Tech support utility in PT8 | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-26-2008 08:42 PM |
DIGI...Tech Support Utility error | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-22-2008 07:36 PM |
Tech support utility | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-04-2007 12:00 AM |
