Old 05-19-2019, 10:29 AM
ericsvizeny ericsvizeny is offline
Default iMac pro recommendations
Would you recommend a 8 or 10 core iMac pro for pro tools ultimate and hd native thunderbolt. 64gb ram and 2 Tb. Just unsure if I should go 8 or 10 core.
Old 05-19-2019, 10:46 AM
Default Re: iMac pro recommendations
Nobody here can give you a clean answer. I depends on your budget and workload.
Some comments:
2019.5 is such a huge performance win you likely want to get on that ASAP, if you are not there already.
The internal SSD is so fast on these Macs you want to maximize that, and plan on running sessions on that, and samples if they can fit...Hopefully the 2TB you have lets you do that. I would personally spend as much money on SSD as I could... they are upgradeable but with proprietary cards and you have to open up the iMac Pro.
The DRAM is upgradeable on these iMac Pro as well, but you have to open up the iMac. So it's good you have configured that well.
Pro Tools under lots of workloads can make use of two additional cores, the down side is the thermal compromise of these iMacs Pros means that all the cores running likely means things are throttled. And you already take a slow down of a few hundred Mhz on the 10 core. And it's $800... and the CPU is socketed and _might_ be upgradeable later.... all those reasons help mean that personally I'd go with the 8 core... especially because I also expect to help manage CPU load with workflow using freeze/commit.
And I'd think hard about spend $$$ on an iMac Pro now when the new $$$? Mac Pro is supposed to be announced this year. I hope that has easier upgrade access, much better thermals, more expansion, etc.. That's actually my position, I was considering a iMac Pro, but really want to see a powerful new Mac Pro. If I was going to by the iMac Pro I would want to listen to one running under load, hopefully others here can give their experience wit fan noise.
Old 05-19-2019, 01:53 PM
reichman's Avatar
reichman reichman is offline
Backing up everything Darryl just said, but adding a chart:
https://browser.geekbench.com/mac-benchmarks
Click 'multicore.' This chart isn't perfect, but in my experience, it's a good shorthand for comparing machines.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 06-01-2019, 12:54 PM
Sugarnutz Sugarnutz is offline
Here's my i9 benchmarks (Disclaimer - This is not an Apple product, but a PC I built):
https://imgur.com/a/k0A8p7n
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 06-02-2019, 06:46 AM
paulo m's Avatar
paulo m paulo m is offline
We recently bought an iMAC Pro. We couldn´t wait for the new MAC Pro and the 2013 model would be a bad investment IMHO.
We went for the 8 core, 64 Gig Ram, 1Tb SSD, Radeon Pro Vega 56, 8 GB. We also bought the optional VESA adapter for mounting on an Ergotron artulated arm.
Also bought a Sonnet Echo 11 Dock to expand connectivity.
Running the system with PT 2019.5 and HDX 1 installed on Sonnet TB2.
No problems with fan noise from the iMAC, it´s really quiet even working for 15 hours a day or more.
We have it connected to a Nexis server, so can´t comment on local storage load here.
So far so good. The only downside is Mojave compatibility to all apps, some are not yet certified, like DADman on MTRX.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
iMac Pro Xeon vs. iMac i7 Nathan W. Post - Surround - Video 6 09-05-2017 05:25 PM
Tranferring Protools 10 from old iMac to new IMac JuergenTilak Pro Tools 10 3 07-31-2012 08:48 AM
24in iMac or 21.5 iMac??? Help the blast 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2010 05:19 PM
sync iMac with 003 and iMac with Mbox2? Jussi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-09-2009 03:24 PM
Any recommendations? sketcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-17-2000 05:58 PM
