Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-20-2023, 01:46 PM
jgiannis jgiannis is offline
Default Carbon - general setup questions
Some general Carbon questions for a very simple setup.
- Can my internet-ethernet cable be plugged into the Carbon? Currently, my mac studio receives internet via hardwire ethernet connection. But the mac only has 1 ethernet port, which will instead be used to connect to the Carbon. But the Carbon has 2 ethernet ports. Can my internet be plugged into the 2nd ethernet port on the Carbon? If not, then what is that 2nd ethernet port used for?
- Is the carbon capable of hosting 5.1 (or more)? I hope to build a small surround-mixing space with at least 5.1.
- Can ALL of my computer sounds be routed through the Carbon? Ideally, any sound-playback from the Mac (youtube, system sounds, iTunes, etc) would be coming through the Carbon, not just Pro Tools sounds. Hopefully Pro Tools doesn’t even need to be open for my system sounds to all come through.
- If the Carbon can playback all of my sound sources (as mentioned above), then is there any use for the rear audio-out jack on the Mac Studio? Currently my stereo speakers are connected through this jack. But it seems like I would have no further practical use for it (which is fine, I just want to make sure I’m planning correctly).
Old 12-20-2023, 02:29 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Carbon - general setup questions
First and foremost it's a pretty good idea to list your system (see my Signature line below)
OK In order ::
No the Network router cannot be plugged into the second Ethernet port on the Carbon . That port is to connect an additional Carbon Pre to expand the Pre amp count to 16
I don't know if you can use a hub with an ethernet port to plug router into and then go out a USB C or like to Mac ?
Or if you have to set up your router to do wireless to Mac ?
Yes the Carbon can support 5.1
Yes the Carbon can play all computer sounds as well as other DAWs just no DSP
for any but PT
No PT does not need to open to playback computer sounds thru Carbon just turn on Carbon and boot computer
However PT can be open and you can switch back and forth from PT to computer sounds or other DAW without closing PT or closing PT session
Personally I would connect my studio monitor speakers to the Carbon's Monitor outs and that way all computer sounds will go thru them or the headphone outs on the Carbon
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 12-21-2023, 10:31 AM
eightamrock eightamrock is offline
I would leave the ethernet cable connected to your mac for hardwired internet.
Then use one of these guys https://www.sonnettech.com/product/t.../overview.html which is the only certified adapter for use with carbon.
I "think" this would work, but someone would have to confirm from AVID.
Old 12-21-2023, 10:55 AM
dominicperry dominicperry is offline
Or you can use the double-dongle............
https://avidtech.my.salesforce-sites...n-Requirements
see the section called "Network Requirements & AVB Adapters"
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 12-21-2023, 02:26 PM
K Roche's Avatar
Well as noted by dominic the Apple double adaptor works as well which is what I use
I believe that sonnetech one will work However can confirm that originally I bought an Amazon basics that looked like the sonnetech you linked and it did not work
https://www.amazon.com/AmazonBasics-...4EALw_wcB&th=1
System :
Enjoy the Journey
.... Kev...
Old 12-24-2023, 09:16 AM
[email protected] mradlauer@gmail.com is offline
I prefer the sonnetech over the double dongle. It's a bit pricey but also more robust and purpose built. I use it both on my mac studio and MBP.
The other adapters out there in the world "might" work but mileage varies and more than likely will not work at all.. I have 3 off-brand adapters that will not work at all.
Carbon - Can't Edit IO Setup andymixer Pro Tools | Carbon 5 01-06-2023 11:04 AM
Questions on Carbon mrgroovy Pro Tools | Carbon 6 04-29-2022 01:37 AM
Questions on Carbon Armando Pro Tools | Carbon 13 07-16-2021 11:40 AM
General Midi Setup duanegoing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-14-2008 11:10 AM
General Setup rOckstar86 Pro Tools M-Powered (Win) 2 07-23-2006 06:33 PM
