will pro tools 9 work on original Mbox interface
Hi..
pro tools 9 will work on original Mbox interface ?? |
Re: will pro tools 9 work on original Mbox interface
No. Neither as Core Audio nor ASIO.
Aaron Mulqueen - 001 HD Native |
Positive? Because it worked with 8. Avid doesn't support it, but if it's an interface and ProTools 9 is capable of standalone, I'm not certain that it won't work...
They had said it was incompatible with 8 but that was only because they don't 'support' it. |
Questionable. but would the new coreaudio driver work with the old MBox? Chris
There was already a thread on this topic: http://duc.avid.com/showthread.php?t=285588
Have you tried it? If the Mbox shows up in other programs through CoreAudio Manager, why won't it work in ProTools? My understanding was that 8.0.4 drops support and it won't start up with the Mbox1 attached, just as any versions after 6.4 won't start up with a 001 attached? Can someone correct me if this is wrong? |
No, I sold that door stop.
Well, that doorstop is the only 2 x 2 USB interface that I own. I was considering buying the new Protools Mbox... but may not now.
You buy the Crossgrade, it does not work, go buy a Pro Tools Mbox, what have you lost?
I have a working protools system currently. 8.0.1 on 10.5.8. If I can somehow use my old Mbox with PT9 on 10.6.x then it saves me money buying a new interface that *does* work.
I'm trying on my B machine. I'll report back with any success/failure. |
Installed CoreAudio 7.4.2 over the top of PT9... that caused PT9 not to want to open at all.
PT9's CoreAudio Manager sees the Mbox but then says "Status: Not Connected (HW not found)". My next trick is to try installing the Mbox 2 drivers... |
Will my Original MBox work with Protools 8?? | mberger79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2017 03:06 PM |
Can I use Pro Tools 10 with the original Mbox 1? | Focuret | macOS | 2 | 03-01-2012 05:34 AM |
using original mbox interface | grooveline | Windows | 6 | 02-05-2011 10:43 PM |
Pro Tools LE 7.3.1cs probs w/ original mBox or osx 10.4.11? | tnixer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-22-2010 06:58 PM |
Original MBox & Pro Tools 8 | jackmackdaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-24-2010 09:48 AM |
