Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 12-30-2011, 12:14 PM
sretepmada sretepmada is offline
Default PT 10.1 crashing when changing I/O settings.
Everytime I try and change my I/O settings and then save, 10.1 crashes..anyone experiencing this?
Am using 10.1 on a mac with hdx card + omni interface.
Old 12-30-2011, 02:05 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT 10.1 crashing when changing I/O settings.
What computer?
What version of the OS?
Did you have a version of PT installed previously?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-30-2011, 03:01 PM
I sorted it with pt support. v helpful. it seems that 10.1 crashes if the outputs are not assigned correctly in the I/O set up box. All good now. HDX working great, no probs.
Old 12-31-2011, 12:31 AM
crizdee's Avatar
Let me get this right! An incorrectly assigned output will cause a crash
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-31-2011, 07:09 AM
panamajack's Avatar
panamajack panamajack is offline
...it seems that 10.1 crashes if the outputs are not assigned correctly in the I/O set up box. All good now. HDX working great, no probs.
All good now? No problems?
Seems like a popup stating something like, "Unsupported I/O option!" or "Nice try, but no cigar!" would be preferable. Maybe even slightly more graceful.
Jedi mind games: "You just spent a fortune, ignore this minor defect, you will not object to these crashes."
Or in the infamous words of the Borg: "Resistance if futile, you have been assimilated."
Old 06-15-2012, 12:03 PM
Earl Martin Earl Martin is offline
I've been getting the same thing with PT 9.0.2. I have been switching between PT rigs that require different I/O setups and every time I switch from Rig B to Rig A and try to reconfigure the I/O, I get a bus thread error and then the multi-language screen of death. I have tried trashing the necessary items with the Tech Support Utility. In my crash log I get a KERN error and FW bus errors, even though I have no firewire connected. I haven't been able to find any other threads about it yet and haven't contacted AVID/ Digi yet either. The only workaround I've been able to make work is to create a new session and import all of my tracks in with the correct mapping already in place. Any help would be appreciated.
Mac OSX 10.6.8
Mac Pro Quad core 2.4 GHz
Protools 9.0.2 HD3 with Magma PCIx Expansion Chassis
Intensity Pro Vid card
IO Settings keep changing LCM Technician Pro Tools Software (Mac) 1 02-06-2013 08:01 AM
I/O settings changing on its own will. MacGreginator Pro Tools 10 0 09-14-2012 05:46 AM
Settings Changing on Their Own NJSoundguy VENUE Live Sound Systems 5 11-14-2011 08:47 AM
Changing I/O Settings in PT8 fooloof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 09-17-2009 05:24 PM
changing IRQ settings mfym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2000 03:24 PM
