Old 02-11-2007, 05:44 PM
tomyco tomyco is offline
Default drum samples
I am new to this forum and to Pro Tools 7.0. Can you tell me if pro Tools has drum patterns built in? Or do I need to buy a drum plug in?
Old 02-11-2007, 05:54 PM
OddsAre OddsAre is offline
Default Re: drum samples
you need a plugin... try Reason 3.0 with the Reason Drums Refill or Strike from Digidesign. Reason will be a bit more pricey when all is said and done, but you also will have a bunch of other syths to use down the road. Plus its fun to use is standalone mode!
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 02-11-2007, 08:24 PM
manis manis is offline
i cant make my reason adapted work with, or sync to, PT LE 7.3.1.., i did find on your 'EXPAND' software instrument that came with the ignition pack, if you search it you will find 'loops' on it, you have to look hard, I only found it the first time the night before last, I am also new too to PT. Also if you have some midi drum files on 'sampletank' (also on the ignition pack) there are a couple of settings for drum sounds via midi info.., 800, 900, and DRY are a couple of examples of settings I found. I have been having the same trouble as you, tried to get BDF to work but there was no content folder and only about 8 sounds.., useless.., also Abelton lite will not sync unless you but the full version, same with Melonome (whatever its called) all very disappointing, but as I say, you will find some nice drum loops and resonable drum sounds on XPAND and 'sampletank.'
bless the fate that brings good friends together.
I Mac 24 inch screen, tiger 10.4.11, CPU dual core 2.16ghz, 2 gig ram, UB.
PT 7.3.6. M Box2
Drum Samples firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-28-2010 07:05 PM
Drum VI Samples drumdh The Drum Room 5 10-21-2009 09:40 PM
Drum Samples rickylaureano General Discussion 7 11-24-2003 02:09 PM
Drum samples?? 22down 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-17-2003 10:06 PM
Drum Samples!? Voutsonios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-22-2001 07:14 AM
