Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 01-15-2016, 10:38 PM
awritersparadise awritersparadise is offline
Default Control won't connect? Via Ethernet cable to router?
My pro tools computer doesn't have a wireless card, but is connected to the Internet via a wireless router via an Ethernet cable .. I wasn't sure if the control app would work with this set up, but it turns out when I pull up the eucon software on the pro tools computer, it finds the iPad and lists it as an option. I thought I was home free!
But.... The iPad just says "not connected" ... I have eucon enabled in pt prefs.. And select the iPad in the eucon software.. But once I save setting and quit..nothing seems to change or take effect. What am I missing?
Custom Thermaltake PC / Windows 10 / 16 gigs of ram / Intel I-9 CPU (12 cores) / UAD Apollo Quad Firewire Interface / M.2 System Drive / 5TB Solid State Session Drive / Pro Tools 2019 Subscription
Old 01-16-2016, 09:00 AM
john1192 john1192 is offline
Default Re: Control won't connect? Via Ethernet cable to router?
what version of EuCon ... 3.3.2 is out ...
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 01-16-2016, 12:40 PM
I have 3.3.2. As soon as I load the ipad app, the ipad shows up in "my surfaces" on the EuControl software on my Pro tools computer. .. but still says "not connected" on the ipad itself. Is there something I need to click, change, or perhaps
another step I am missing?
Old 01-16-2016, 12:58 PM
ahhhh.. funny how many PT Problems can be fixed with a simple reboot. haha. Decided to shut down the computer, reboot both it and the Ipad.. and Voila!! -
Old 01-19-2016, 08:32 AM
cool .. i have to pickup the USB to Ethernet to try this .. please let us know if it is fast and Snappy ..
cheers john
Old 01-19-2016, 04:04 PM
Yes, it's pretty instant.. doesn't feel laggy at all. Good luck with yours!!
Old 02-12-2016, 08:49 AM
hi, i have still not done this yet ... as by this picture it seems i need to have another USB Hub or power adapter and a USB Split Cable - just for this - Apple, please stop taking money out of my pocket .. ??
so now, instead of having a Long Ethernet Cable to the iPad with a duple adapters I am now Tied to the length of USB again .. Lame ..
and i would have to upgrade my 2.4ghz devices so i can run Control on 5ghz on Network ... as it is so Buggy for me at 2.4 it is unusable .. hence why i have been looking for hardware solution ..
rant over .. back to finding some other solution ..
happy to hear your setup is working ..
cheers john
Old 05-11-2016, 12:49 AM
Ale Ale is offline
Default Re: Control won't connect? Via Ethernet cable to router? SOLUTION ETHERNET WORKS!
Finally YES YES YES
IPAD ETHERNET WOOORKS NO WLAN ANYMORE
All you need is:
1. The all new APPLE Lightning to USB3 Camera Adapter
2. The Apple USB Ethernet adapter (connecteted to the camera adapter)
No configuration. It just works, and better than Wlan
You MUST have your Power Adapter connected to the apple USB3 Adapter.
Otherwise you get the message that the ethernet adapter takes to much power and it does not work.
The nice thing is that the ipad gets loaded while running.
All tested apps seem to work with this ethernet solution.
Browser, Dropbox, email.........
See this picture PTControl running without wlan.
Ale
3x PT HD Ultimate 2019.6/10 6/12-Core Westmere/ 48 GB / OS 10.12.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2019.6 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
www.tonstudio-gress.de
www.facebook.com/TonstudioGress
Old 05-11-2016, 04:17 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
If you are having problems with your ipad not connecting, make sure it has the latest version of the OS installed. There was a problem whereby if you had used Safari or other browser before connecting to PT Control, the OS would stop other apps from connecting. I had this problem which has been solved with the OS update. Now running OS 9.3.1 on my ipad Air.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 431.86- 2 x Internal WD Blacks + MSATA card - Davinci Resolve 16.1 - Canon HF G40
Old 05-11-2016, 10:05 AM
"You MUST have your Power Adapter connected to the apple USB3 Adapter.
Otherwise you get the message that the ethernet adapter takes to much power and it does not work."
this is not truly the way i would like it to work .. i posted his in the other thread as well .. we need to Power to come down the Ethernet line not USB .. unless someone makes a battery that can be mounted directly to your iPad so you do not have to be tied to the short USB power leash ...
Originally Posted by Ale View Post
Finally YES YES YES
All you need is:
Ale
Ethernet Switch or Router? simonjewel Artist Series 15 09-13-2015 05:09 AM
Custom Ethernet Cable for Artist Control and Mix? TeamContra Artist Series 5 01-17-2014 08:56 AM
Help, Control 24 not being picked up by ethernet cable. ghettostarz ICON & C|24 2 10-22-2009 03:24 PM
Question regarding router/ ethernet connections Dopamine ProControl, Control|24, Command|8 2 05-15-2007 09:42 AM
Where do you connect the Ethernet cable if the DSL Imagine ICON & C|24 1 04-18-2004 12:26 PM
