Old 03-11-2007, 01:55 PM
minister's Avatar
minister minister is offline
Default AC3, is it Sample Accurate?
when converting to an AC3, does it maintain the Sample sync? meaning, we have 2 Reels of a film that will go into DVD Studio Pro as 2 separate Mpegs and AC3 files. the editor will butt-splice them. there is no issue with the butt spliced PCM files, but will the AC3 files also transition without a hitch?
mr. neyrinck?
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 03-11-2007, 01:59 PM
The Chinese The Chinese is offline
Default Re: AC3, is it Sample Accurate?
Minister-
That's a big maybe. The Concatination pointcan be problematic, because the AC3 File isn't perfectly frame accurate... I would provide handles. When I was at TCS, we had problems like this frequently, and solved them by provided a few seconds of handles, so the DVD guys could find the point where the AC3 frames can fall in sync.
Think of it as 24Fr across 30Fr Video.
-Todd
Old 03-11-2007, 02:04 PM
minister's Avatar
the Chinese,
JEEEZ! i posted that 30 seconds ago. CHOP CHOP! he he...
got it!
i was afraid of that....
i will concoct a concatenation plan,
Tom Hambleton CAS
IMDb
-Starcrash
Old 03-11-2007, 02:11 PM
the Chinese,
got it!
He he he Sittin in front of the computer beats weeding the front lawn and picking up cat poop....
Chino
Old 03-11-2007, 02:14 PM
minister's Avatar
chino
i'll concoct a concatenation course and you clean up the cat caca.
rocka!
Tom Hambleton CAS
IMDb
-Starcrash
Old 03-11-2007, 03:47 PM
airon airon is offline
All the dolby recording sessions I've been at, the consultant tested the AC3 crossover between reels, so provided that guy has done his job, the DVD guys should be happy.
"My ego comes pre-shrunk" - Randy Thom
Old 03-11-2007, 03:58 PM
minister's Avatar
hi airon,
this is not from a Dolby Printmaster via a DMU...
this is a software encode for a DVD of the 'sales version' of the film.
Tom Hambleton CAS
IMDb
-Starcrash
Old 03-12-2007, 05:35 PM
sleadley sleadley is offline
I have encoded quite a few DVD's for commercial release. I use and recommend the AC3 encoder that is available for Pro Tools made by neyrinck It is timestamped and is sample accurate. I have checked it with long program materials and it always correct.
my 2c
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 03-12-2007, 07:37 PM
Sonsey Sonsey is offline
Hey Tom, I tried this myself on a DVDSP project a while ago and it DIDN'T work - definite sync problems. However I was using Compressor not the Nerynck plugs, so YMMV. However my solution was to do the two pieces as separate TRACKS inside DVDSP and simply have one jump to the other. Of course depending on the DVD player this could cause a slight pause as the track jumps, so it might not work for your application.
"Ya canna change the laws of physics..."
-Montgomery Scott
Howard Sonnenburg
Atomic Audio
Ottawa, ON
Canada
Old 03-12-2007, 10:11 PM
Tstein Tstein is offline
AC3 is not frame accurate. Dolby admits that sometimes you will get lucky and an edit (or edits) will work. But sooner or later you will have get a glitch. This is one of the reasons they invented Dolby E.
Good Luck,
Ted
HTML code is On
Isn't PTLE sample accurate? Kempo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-16-2010 03:34 PM
Sample accurate midi? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-10-2005 12:48 AM
is reason on pt sample accurate? halfguard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-18-2004 02:39 PM
Rewire Not Sample Accurate? Siegfried Meier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2003 12:41 PM
