Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 08-26-2008, 05:37 PM
etwilliamson etwilliamson is offline
Default X SAN ProTools Support?
The facility I work at recently purchases an X SAN system. We were assured that "ProTools can read and write to it just fine". The X SAN drive is recognized by OS X (Leopard) and ProTools (7.4.2) but we are unable to change the volume type of the drive from "Transfer" to "Record" in workspace. (When tried, we receive the error ""LA_Post" cannot be designated as an Audio volume because it is not a fixed, removable or MediaNet volume" (The volume is named "LA_Post".) Any help would be greatly appreciated!
Old 08-26-2008, 07:42 PM
Craig F Craig F is offline
Default Re: X SAN ProTools Support?
in short you were lied to.
there may be a way to trick PT but I have not done it
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-27-2008, 01:32 AM
I believe iSCSI systems work with PT but not Xsan.
frank.
Old 08-27-2008, 02:40 AM
mix109 mix109 is offline
Frank is right
ProTools has it's own way of handling File level Sharing or Block Level Sharing
You actually need a third party software in order to utilize the XSAN and be able for the
storage pool to work with PT(r/w) via iSCSI:
(at least this is what they claim)
http://www.commandsoft.com/software_fibrejet.jsp or
http://www.fibreshare.com/index.php?...on=com_content
Or go for a complete solution like:http://www.ardistech.com/ http://www.studionetworksolutions.com/
Old 08-25-2009, 05:19 PM
FibreJet and other Volume Locking storage solutions work because they are HFS+based. Xsan if File Level Locking,
Old 08-26-2009, 01:31 AM
Petevsi Petevsi is offline
Hi
sadly Xsan can not be used as a audio drive (for record or playback) by PT and whoever sold you it should know that; Digidesign have been telling people that it can't since Apple released it.
Like someone else said its to do with the way PT accesses the file system. PT don't work with software based raid systems which is really what Xsan is. There are ways to fool PT to work with it but having tried it I would not recommend them. That said you can play video off a Xsan in PT which speeds thing up a great deal and depending on the speed of your fibre channel connection copying sessions to and from is very, very fast.
The iscsi route can use the Xsan storage (I believe), but be sure to test before buying
Hope this helps
Pete
MacPro Trash Cans, GBLabs Space, D-control, artist series, c24, Protools 12 HDX, VoiceQ
www.vsi.tv
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
Is the C24 will support protools 11? CLASS-A-DUDI TAMIR ICON & C|24 2 03-28-2013 08:17 AM
Protools support, Im stuck =( Jep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-16-2010 03:46 PM
Will Protools 8 MP support more than 18 i/o?? milestone Pro Tools M-Powered (Mac) 20 03-07-2009 09:51 AM
TECH SUPPORT - When will MPs be MP for Protools?? booyakka Pro Tools TDM Systems (Mac) 9 08-02-2001 05:25 AM
