  #71
Old 02-09-2019, 09:18 AM
basslik's Avatar
basslik basslik is offline
Default Re: Worth replacing 2008 Mac Pro for upgraded 2010 Mac Pro?
Originally Posted by LDS View Post
Nah. It is common internet advice, and it will boost your geekbencj scores considerably when you run ram in just the 6 slots due to tripe channel operation...
...but I run ram in all 8 slots. It might be that 64 gig is the magic number, but my system is just a lot smoother and snappier to use when running 8*8 gig sticks rather than 6*8 gig, despite the 3000 point hit to geekbench scores.
That is very interesting indeed. I currently running 2x16gigs, PC3 14900, server memeory, which is incredibly smooth since I upgraded the CPU to the HEX core. The memory is faster what the computer requires (downsteps) I guess, but runs great.
Looking to find a matching stick on Ebay, and going to make sure it's the identical match so there is no conflicts. thanks
MAC PRO 2010 5,1 3.46hex 96ram - Mt. Lion 10.8.5 - PT 9.O.6 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
  #72
Old 05-09-2019, 08:46 PM
basslik's Avatar
GOOD EVENING EVERYONE,
ANYONE
Okay I just purchased another 2010 2.4 GHz Quad Core Xeon E5620 x2,
I am installing (2) X5690's 3.46 CPU's.
Do I have to update the firmware ? THANKS
  #73
Old 05-11-2019, 11:59 PM
LDS LDS is offline
ANYONE
Nope. The firmware is only need to upgrade a 2009 Mac Pro to 2010 specs.
littledevilstudios.com.au
Pro Tools Ultimate 2018.12. OSX 10.13.6. HDX. Avid Omni. Mac Pro 5,1 12x 3.33Ghz. 64Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI Radeon HD5770.
Free Lexicon 224XL Impulse Responses
Free Sony DPS-V77 Impulse Responses
  #74
Old 05-12-2019, 12:33 AM
YYR123's Avatar
YYR123 YYR123 is offline
How much did you pay? I have seen some machines locally that are 2009’s and about $425 USD.
Daniel
  #75
Old 05-12-2019, 12:54 PM
basslik's Avatar
Thanks LDS, greatly appreciate the info from both of you, as well as others.
The current one I have now since I learned of this great upgrade, is a 2.8 single CPU, 2010, which I paid $300 for, plus the $90 for the CPU, and running perfect.
I didn't think about the single CPU thingee, and realized I had sold my 2008 2.8 dual for a single CPU 2010.
The 2009's seam like to much of a hassle with the de-lidding.
So now I purchased a 2010 2.4 Dual (CPU), I got for $300 as well.
Will put back the Original CPU on the 2010 in just upgraded, and put back the original CPU and unload that one.
I ordered another X5690, and will put both of those in the 2010, 2.4 dual tray.
  #76
Old 05-14-2019, 07:35 PM
basslik's Avatar
Good evening everyone,
Okay I made the upgrade 3.46(2x), X5690's, running 64ram.
I read somewhere on here or perhaps the Mac Forum. But not sure exactly how much ram support for the X5690's ?, and I'm sure the W3690 is half that I believe.
Also max the ram VS running triple channel instead ?
Thank you all kindly.
  #77
Old 05-14-2019, 08:22 PM
arche3's Avatar
arche3 arche3 is offline
I would just max the ram. I don't think the triple channel ram thingy matters for protools as much as amount of ram.
Sent from my SM-G975U using Tapatalk
  #78
Old 05-14-2019, 09:27 PM
I would run it triple channel as it also makes CPU more efficient -- and 64GB today is plenty.. if it's not enough you would know, then performance would not be as important as getting things done.
  #79
Old 05-15-2019, 08:48 AM
arche3's Avatar
Does it actually help the CPU in protools? Has anyone actually tested this?
  #80
Old 05-15-2019, 11:17 AM
basslik's Avatar
I'm also curious, currently have (2) 32gigs on each tray, which is not triple channel. ?, thank you all
2008 Harpertown quad 3.0 to 2010 Westmere quad 2.4??? audioluche Pro Tools HDX & HD Native Systems (Mac) 2 11-15-2012 06:14 PM
2008 Mac Pro w/ lots of ram or 2009/2010 w/ low ram? Ross H macOS 6 08-29-2011 03:19 PM
Mac Pro 2010 2.8 GHz Quad Core vs. 2008 2.8 GHz 8-Core audiosf macOS 3 04-07-2011 02:27 PM
NAB April 2010 - anything new ?? scotsman Pro Tools TDM Systems (Mac) 16 03-09-2010 11:40 PM
Replacing stock 9600/350 (upgraded G3/400) video card Marco Migliari Pro Tools TDM Systems (Mac) 0 11-13-2000 06:51 AM
