AIR Hybrid 3.0 - PT Says Authorization Is Missing/Damaged
Just purchased it from AirTech and after installing it and using the Hyrbid Authorizer, when I load up PT (10.0) I get the follwing:
Pro Tools could not load the following plug ins because no valid authorization could be found, the iLok key was not connected, or the plug in was damaged Hybrid.aaxplugin Any ideas?
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
Re: AIR Hybrid 3.0 - PT Says Authorization Is Missing/Damaged
From memory, Hybrid3 doesn't require an ilok just a single activation when launched. You click activate via internet, it takes you to the web page and you enter the code from where you downloaded it.
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
What version of Pro Tools 10 do you have? I think you need v10.3.6 or higher, but you would need at least a version that supports AAX plug-ins
Hi Guys. Yes, before I created this post I did activate Hybrid over the internet.
Doesn't AAX work with all versions of PT10, or do I have to upgrade to 10.3.6? I still use 10.0 and it works flawlessly. Can you confirm that AAX DOES NOT work with 10.0?
According to your signature, you are on Windows XP. Hybrid 3 requires Windows 7 or higher. This could be a factor, unless your signature is outdated.
Hi. Please ignore the signature. I'm on Windows 7 and have a qualified PC. This has nothing to do w/the OS. Thanks.
Hybrid is asking for iLok Authorization after updating to Pro Tools 10.3.x | MErnst | Virtual Instruments | 33 | 05-24-2014 08:47 AM |
Hybrid Authorization | ChristianAllanRamirez | RTAS & TDM Plug-ins | 7 | 07-31-2013 12:38 AM |
Hybrid Is Missing | GTBannah | Windows | 11 | 08-18-2011 04:41 AM |
Hybrid Missing | SupreGlu | Pro Tools 9 | 1 | 04-17-2011 01:00 PM |
Transfuser and Hybrid authorization issue | Gearaddictz | Virtual Instruments | 3 | 02-11-2011 12:50 PM |
