Re: Poor sound levels on my 001 bounced wav\'s - please help
let's say what you just explained maybe makes sense to someone in 6th grade. can you explain it to me like im in the 1st grade?
i realize that to lots of people what you said makes perfect sense. i REALLY appreciate the help. |
Imagine you've got a mixer. In a standard mixer, you feed sounds into separate channels (your tracks in PT), and these channels all go into the (insert Cleopatra theme music) MASTER FADER. This is like the volume button on your stereo.
The difference between PT and a regular mixer is that without a master fader you can still hear all your audio, but you can't control it. You need to create a master fader (CTRL-SHIFT-N) if you want to control the overall volume. Do you have the Digi demo sessions ("Be there" or something like that) ? Look at the master fader and play with it. |
aprice88, to open a "master fader" track you need to 'create new track' and select the type to be the master. Im not sure if you got that from what was being said. Then you crank that, without clipping, and add the plugs...
er... I guess I just repeated Paul.... 6 of these, half dozen of the others, I suppose. [img]images/icons/smile.gif[/img]
Cinema Chains - sadness at poor levels | MIKEROPHONICS | Post - Surround - Video | 63 | 08-15-2012 03:40 PM |
How to batch convert 32 bit wav's to 24 bit wav's? | tlester | Pro Tools TDM Systems (Mac) | 2 | 10-06-2007 11:05 AM |
mix levels low when bounced to disk | wizdoom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-01-2005 04:06 PM |
Possible reasons for poor MBox Source levels | RichAucoin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-03-2005 01:37 PM |
SoundJam won't "see" wav's bounced in PT LE 5.1? | RobbaDobba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-19-2002 11:51 PM |
