Midi issue
I’ve got 2 instrument tracks both with midi recorded on and each one has the access virus plugin in on. For some strange reason one track is playing the other tracks midi part aswell as the part on its own track. I haven’t got a clue why this is and how to stop this. Hoping you guys can help me out
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Midi issue
Probably need to assign each midi track to its own midi channel(by default, they probably are assigned to ALL). Then you may need to match that assignment in the VIRUS plugin. Having said all that, my usual configuration is to put the VI on a stereo INSTRUMENT track(and not use midi tracks). In your case, that might mean 2 instrument tracks with VIRUS inserted on each(you can copy/paste midi from the midi track to an instrument track). Its also possible to paste midi from 2 midi tracks onto the same instrument track(depending on your needs) but that requires Paste Special>Merge IIRC(I'm not sure on this as I am no midi genius!!). Assuming you already know to select View>MIX windows shows>check "instrument" to open the assign at the top of the MIX window tracks
Re: Midi issue
Sorry Albee I meant instrument tracks. One has no midi on it and the other has midi on it but the one with no midi plays the midi from the other one also. Hope that makes sense
Raoul Crane
Re: Midi issue
It does make sense. Enable instrument view on the edit screen and check the routing on each track to see what's what. PT has a long history of screwing this up.
Re: Midi issue
Already checked that and each track is assigned correctly, I think ???
Raoul Crane
Re: Midi issue
If the tracks in question are supposed to be going to the same vi and you want them to play different sounds from said vi make sure each track's MIDI is going to a separate MIDI channel (track 1 to MIDI channel 1 of the vi, track 2 to MIDI channel 2, etc.). Also make sure Virus can handle multiple MIDI streams. While looking at Virus make sure none of the sounds are set to respond to MIDI omni.
Re: Midi issue
Another solution, and how I normally do it when I have multiple instances of the same VI, each on their own instrument track. I set up a MIDI track for each part and direct the MIDI output of that track to whichever VI I want it to play. That normally avoids any issues such as you're describing.
Jack is right, though, PT has had issues of the sort you're describing.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: Midi issue
Donald's way of working while old-school keeps one clear of these types of problems. What makes this problem really bad is it's inconsistent and that makes code debugging difficult. |
MIDI problem - Midi Studio Issue | Microphone33 | MIDI | 4 | 02-27-2016 11:49 AM |
MIDI problem - Midi Studio Issue | Microphone33 | Virtual Instruments | 0 | 02-07-2016 02:09 PM |
midi issue- can see midi signal but cant's control Xpand2 | macroniche | Pro Tools 10 | 1 | 08-02-2012 12:16 AM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Issue When running Midi and more than one Midi Track | amayhem | MIDI | 11 | 11-05-2009 06:52 PM |
