  #61
Old 02-25-2017, 10:51 AM
Sawbuck2017 Sawbuck2017 is offline
Default Re: Eleven Rack Editor - Info
Compatibility:
Since W10 came out, I haven't been able to get the Editor to start without crashing. I installed the most recent Eleven rack drivers 1.1.11 and still experienced the problem. I was finally able to get it to work successfully by using the following settings:
I have a shortcut to the editor on my desktop. I right click the icon, selected properties, then compatibility tab. Then you select compatibility for all users. Finally, select compatibility for windows 8 and check the disable the display scaling.
  #62
Old 02-25-2017, 11:35 AM
martinaston martinaston is offline
Originally Posted by Sawbuck2017 View Post
Compatibility:
Thanks for this - I still encounter the issue occasionally and the improvised remedy is certainly unsatisfactory
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven rack editor freezes baribari Eleven Rack 2 02-17-2014 07:40 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
