Old 07-18-2017, 04:29 PM
AHarmonson AHarmonson is offline
Default Quickest Way To Duplicate Headphone Sends (PC PT 12)
I did quite a bit of searching the forums and haven't quite found what I'd imagine to be a simple command. I'm looking to duplicate send levels from sends A across all tracks into sends B and C for the purpose of quickly duplicating an already set headphone mix from which I can tweak from there. I typically alt click the send A on each track, move to send B and C, and then change the outputs of sends B and sends C across all tracks.
Thanks!
Aaron
Old 07-18-2017, 05:40 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Quickest Way To Duplicate Headphone Sends (PC PT 12)
Hi, welcome to the community.
I'm afraid PT won't do what you want it to do -- you need to create submixes and send from there.
Janne
Old 07-18-2017, 10:31 PM
DarkandKurious DarkandKurious is offline
I'm sure I've done this before - I'm not sitting in front of PT, but off the top of my head it was something along these lines:
- Make a group of all the tracks going to the headphone mix;
- Add the new headphone outputs across the selected tracks (shift+option once all tracks to be cued are selected);
- Change the edit window view to the automation lane for Headphone Cue 1, add a breakpoint and copy a selection from the start across all selected tracks (this is why making the group is helpful);
- Change the edit window view to the automation lane for Headphone Cue 2 and go 'Edit' menu > 'Paste Special' > 'To Current Automation Type', then delete the breakpoints at the end of the selection.
Convoluted, but quicker than option clicking and dragging sends and then changing the outputs.
EDIT: Just noticed you said PC - I've written for Mac and I don't know the equivalent PC commands, my apologies. Also, just checked that this works, and edited to make things clearer.
MacBookPro15,3 i9 32GB Vega 20
macOS 10.14.5
Pro Tools 2019.5 Vanilla
Antelope Audio Zen Tour
Old 07-19-2017, 12:18 AM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Pro Tools 2019.10. UAudio Apollo 8 Duo & Apollo Twin. Custom PC i7-7700K 16 Gb Ram Thunderbolt 3 SYSTEM-1KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Mackie MCU Producing My Own Life
Old 07-19-2017, 11:09 AM
natenajar natenajar is offline
Originally Posted by gonsdeejay View Post
Maybe you Need this!!!!!Attachment 8886
Wow terrrific
Headphone Mixes from sends macrae11 Pro Tools TDM Systems (Mac) 7 02-02-2007 07:54 PM
Can headphone sends induce noise? guy.fi Tips & Tricks 1 01-26-2007 05:57 PM
headphone sends dean7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-29-2003 01:17 PM
headphone mixes.. sends.. help please metaltim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-28-2003 03:09 AM
Sends for headphone mix vocalize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-03-2002 09:43 AM
