Old 01-25-2000, 01:01 AM
skinnyman skinnyman is offline
Default PT24, Bit3 and SCII
Hi --
I have a new PT24 system which I am using in a Bit3 expansion chassis with a non-TDM SampleCell II PCI card. Because the Bit3 requires an odd card order, I need a longer TDM cable than I currently have to actually put things in the proper order. Right now I get error messages (6047 and 6009) if I try to switch between PT or a sequencer that uses PT and SC software, or if I try to use PT and SC in the same song. It seems credible to assume that the longer cable and correct card order will fix my problem, but I just want to make sure of this before I spend the money, because I can't really afford it and things work fine otherwise. Is there any reason that I can't use a non-TDM SCII card with a TDM PT system, or anything else that might cause this problem?
Thanks
O Eaves
difference between PT24, PT24 Mix and Mix+ ? John H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-16-2002 09:11 AM
SCII & MacOS 9.2, SCII & Windows Me Compatibility? cmores Digidesign Hardware & Software 0 12-10-2001 10:17 PM
SCII+ TDM and PT24 Mix with PT 5.0 Frank Senior Digidesign Hardware & Software 4 01-12-2000 10:09 AM
bit3 chassis creaturestudios Pro Tools TDM Systems (Mac) 3 10-17-1999 06:53 AM
SCII level lower in PT than SCII Farmer Dave Digidesign Hardware & Software 14 04-15-1999 03:40 PM
