Old 12-24-2017, 03:35 PM
jre3132 jre3132 is offline
Default 12.8.3 Distortion
I've seen this problem on other versions, but didn't find anything when I searched for the new version. Anybody else having soft distortion when the master/sub levels get near the top? Around -4 and up. I've pulled up some sessions that were fine in previous versions with an L2, L3, and ML1 on the master with the ceiling usually set to -0.2 (one on each sessions, not all on one...) and it sounds like I'm overloading everything. This is driving me crazy...is there a fix or should I just revert back?
I'm also getting an AAE -9172 error saying Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue. I haven't really had this error before. I found some suggestions online about changing the hardware buffer size or limit plugin use (yeah right).
File Type: png Screen Shot 2017-12-24 at 9.11.58 AM.png (55.3 KB, 0 views)
Old 12-25-2017, 06:12 AM
musicman691 musicman691 is online now
Default Re: 12.8.3 Distortion
How about some system info so we can help out?
Old 12-25-2017, 07:17 AM
Yeah....that would have been helpful....I knew I was forgetting something....
Mac OS X 10.13.2
PT HDX 12.8.3
Mac Pro 3.7 Quad Core Intel
12GB RAM
2 HDX I/Os
Old 12-25-2017, 08:40 AM
Mac OS X 10.13.2
PT HDX 12.8.3
12GB RAM
2 HDX I/Os
Can you try it with just one I/O box and see what happens? Do you have the right HD drivers?
Old 12-25-2017, 11:58 AM
One I/O yields the same result. The audio driver is 12.8.3 but didn't install when I updated Pro Tools. From memory, I was thinking the Pro Tools installer usually updated the driver to the current version as well (I may have that wrong). I had to go back and install it separately. I wonder if that could be causing the problem.
Old 12-25-2017, 02:49 PM
That may well be it. From what I've been seeing the driver has to be updated as part of the install of the 12.8.3 update; it's not an automatic update of said driver.
Old 12-25-2017, 03:21 PM
ok....after trying both I/Os for output, checking routing, checking the db25 connectors to make sure a wire wasn't shorting, reinstalling the older audio driver, and a few more things....I started disabling plugs on these sessions. I'm not sure if this could be it, but it appears to be a limiting plug on the master buss (I typically use a stereo Aux instead of a master fader). Waves L2 and L3 sound the worst followed by the MCDSP ML1. I'm not pegging very hard at all and have the ceiling set to -0.2, but ANY amount of attenuation sounds like absolute trash now (distortion). Any attenuation sounds like I’m completely overloading the main outputs.
Could there be something between the audio driver, final plug-in, and final output that the plugs are somehow affecting? Is that even possible?
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 12-25-2017, 03:32 PM
Another thing that came to mind is that waves released a new version a few days ago and I updated to the latest. I'm sure there probably wasn't a change to most of the plugs, but it did happen at the same time. I would consider it more of a possibility if the other limiters weren't doing the same thing.
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 12-25-2017, 08:17 PM
DarkandKurious DarkandKurious is offline
To check it is not the limiters, pull the ceiling of the limiters down and hear if they clear up - then you'll know if it is the plugins being weird or the the output.
As I don't have an HDX rig I'll be guessing blindly - what is the calibration set for? Is the output of PT too hot for your monitor chain?
Maybe the update has reset some of the hardware setup. I hope you find the gremlin!
MacBookPro15,3 i9 32GB Vega 20
macOS 10.14.5
Pro Tools 2019.5 Vanilla
Antelope Audio Zen Tour
Old 12-28-2017, 05:09 PM
The Limiter ceiling deal was intermittent.
So after nothing else worked, I wiped the mac and reinstalled everything....twice. The first time I kept getting aae errors. Luckily, I remembered just before the second wipe that I hadn't disabled my mercury bundle and was able to deactivate it. That was a close one....
So I reinstalled 12.8.2 and refuse to move up to 12.8.3 which is fine. Now I'm getting 9171 errors which look like trouble communicating with the HDX Card. Before the reformat it was 9172 errors. Are there any alternatives to swapping out the cards?
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Distortion and Vox & Other FX rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-08-2005 11:36 PM
Distortion! austinslide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-03-2004 05:52 PM
mic distortion please help mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2003 02:59 PM
anyone have got big distortion in HD? tamtamstudio Pro Tools TDM Systems (Mac) 9 10-15-2002 12:12 PM
Distortion Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-28-2002 01:09 AM
